Hey all just wanted to ask the forum members a quick question. I have a g-tech pro the rr version so you kno I had to take my car for a spin to see how the device works. I have everything setup and i went for a straight line run, I must say it disturbed the hell out of me I have a 95 gtst with the following mods 3" turbo back exhaust, pod filter, fmic, stage three clutch, boost turned up to 10 psi, plugs gapped to .8mm, no tune and running 91 octane gas as that is the only gas available over here and it is probably 95 ron to you guys cause we import directly from the U.S.A.. Nehow heres the prob I took my car on a quater mile run and came up with some disturbing numbers FOR HORSEPOWER i got a figure of 183 and a quatermile time of 15 seconds on average. Now the time isn't Really an issue but the hp figure, 183 comeon I have to have more horses than that and I have the weight of my vehicle as 3500 pounds. With the mods I have listed does this power figure seem correct. Also wanted to know if I could use xylene in place of toluene as an octane booster and if there are any negative effects to the cars engine as compared to using toluene? Thanks in advance guys.
https://www.sau.com.au/forums/topic/183055-g-tech-pro-rr/
your ECU has probably dropped back onto the lower octane maps, which is cauing you to lose power. depending on how realistic the dyno is, you probably shoudlnt expect much more than 200 or so hp with those mods anyway... i'd say once you get some 98ron fuel and reset the ECU, you might get 200 - 220 hp.
For benchmarking purposes, I got ~230rwhp with 3" turbo back xorst, high flow cat, FMIC, 12psi, pod filter, cold air intake and SAFC2 tuned by matt spry @ PITS.
https://www.sau.com.au/forums/topic/183055-g-tech-pro-rr/#findComment-3319507
weird, do you have the exact weight of the car?
I've got a G-Tech pro RR at home, that's the one with the serial cable to download the data?
basically what i do is,
plug it in:
put in car weight first
then calibrate the RPM
then do the axis calibration(what a pain in the arse to do)
then put in a shift light, i have it starting at 7000(so two lights hit on), then 7500 the four lights go on and I change gear
183hp sounds really shifty though :S I got 194 on my GTS4 auto!!! and a 14.6 1/4, so there must be something odd going on :D
https://www.sau.com.au/forums/topic/183055-g-tech-pro-rr/#findComment-3319599
oh and I'm using 98RON so you might want to see if you can get some better petrol, then once that happens, reset the ECU(remove positive from battery, then put foot on the brake for a few seconds), then try it :D hopefully it gets better, post up your new scores :)
https://www.sau.com.au/forums/topic/183055-g-tech-pro-rr/#findComment-3319601
plug it in:
Dont Have the exact weight just put in 3500 pounds as a rounded off figure. The axis calibration is when you take off to get the g-tech started but only roll forward a couple a feet so that the directional arrows work, did that if thats what u meant.
oh and I'm using 98RON so you might want to see if you can get some better petrol, then once that happens, reset the ECU(remove positive from battery, then put foot on the brake for a few seconds), then try it :) hopefully it gets better, post up your new scores :D
Yea my gas is real shitty over here only gas available is your 95 ron equivalent. So I'm gonna start mixing my own brew getting the ron as close to 98 as I can then I will reset ecu once I have ran a complete tank thro my system and start using my mix everytime I fill up and see what happens. Will post my results. I really think its the gas, plus I have no tune the tune is stock.
https://www.sau.com.au/forums/topic/183055-g-tech-pro-rr/#findComment-3320922
The Gtech uses the weight as an input to the calculation of horsepower, so that needs to be accurate and include everything - so dont forget to add the weight of the driver (and passengers). Also it will read a bit low on horsepower as it assumes no wind resistance.
The quarter mile time on the other hand is directly calculated from the accelerometer input, and should be very accurate.
https://www.sau.com.au/forums/topic/183055-g-tech-pro-rr/#findComment-3320968
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
