Gday,
On my r33 gtst I've worn my right front inside shoulder down bare. I'm guessing I've got too much neg camber on this front wheel. Left front is heading down the same path.
How is the camber adjusted on an r33, is it adjustable without buying an aftermarket camber pin kit? Or is this more to do with alignment? The car itself tracks straight, hence i'm guessing camber problems.
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/
I like the standard camber angle and would leave it alone. if you adjust it for best tyre wear the car will handle like sh1t. Just take the tyres off and swap them over so they wear on the other side. my falken's wore badly like this. i've had bridgestone s03's now for about 10,000km and havent flipped the fronts yet and they dont even look like wearing unevenly.
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382516
I dont know about rotating for better wear. A lot of performance tyres are directional. I'd recommend the camber adjustment kit or an extension on the standard adjustment. Whether it will handle like shit or not depends if you are racing. For street, I can tell you it makes no difference to handling....how do I know?....cos I had all four of my wheels camber adjusted back in for wear reasons. Go to a reputable suspension mob for quality advice RB25 my good man!
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382537
you can still swap side with directional tyres, you just need to have them rotated on the rim at the same time (so they point the other way).
And i'd check both camber and toe-in, it can probably be adjusted within the factory adjustment without needing a kit.
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382564
guys - in my post i said to take the tyres off the rims. so what you do is leave the rims on the car and swap tyres keeping them pointed in the proper direction. this will wear them on the other side. trust me - i do it all the time.
and no - you cant rotate directional tyres. i do this coz i have 235 on the front and 275 on the back....
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382659
i was telling my mate to do this just yesterday
i didnt think some one would think this was as well
just goes 2 show that great minds think alike :D
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382715
RB25.....fair cop, I agree you could swap the tyres. But I think the best would be to sort the prob out once and for all ?? Each to his own....I just couldn't be stuffed rooting around every couple of months swapping tyres. My tyres were wearing out on the inner side down to bald at around 6-8 months. That would mean, after swapping, I would still only get 12-16 months out of a set of fronts...maybe a tad longer on the rear. Now I have the problem sorted, I've seen diddly squat wear on front or back....no stuffin around...no change in handling.
Just my experience.
cheers Ozzy
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-382779
Not enough negative camber. Same as my car, got kmac strut tops and still cant get enough. Grrrrr.
If you have your car set up for good front end grip under spirited driving with some decent negative camber, it will wear the inside edge if you just drive around sedately.
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-385029
350z's wrx's and hsv's are common victims :) I love to chop blokes in their R8's. they think theyre unbeatble in thier heaps of sh1t. i like to sh1t stir em at the next set of lights --  whats wrong with you car mate? why cant your big v8 beat my jap crap 2.5litre 6?   I dont even bother racing these morons anymore - i just rev the skyrine @ the lights, let em drop the clutch and then i putter off like nanna.
let the whoring end.....
hahahahahhaaa I LOVE IT!!!!
hahaha!!! I am not alone :)
https://www.sau.com.au/forums/topic/18315-front-tyre-wear/#findComment-396355
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
