i thought you had a ross balancer? I guess you made the switch? which makes you well qualified to ask which is better! :)
no i had an N1 item on the last engine and N1 oil pump. Got a JUN oil pump this time, in an effort to keep the inner ring of it in one piece i got the 1000hp ATI item. People HARMONIC VIBRATION KILLS OIL PUMPS thats why std pumps live ok to 7000rpm N1's live ok at 8000rpm rev them any harder and they fail due to vibration. This is the reason you need to carefully choose your balancer.
Also i am sure that if people are able to run big HP figures using the std balancer, then even if i exceed over 600hp, the ATI balancer would still perform better than the factory one; Or would other problems (unknown to myself) occur ??
Can someone answer the above question?
I don't think i'll need/want to go above 350rwkw, as my car is set up for motorkhanas and the occasional track, so 350rwkw is probably already too much for a RWD car :yes:.
its not the power levels...its how hard you are going to rev it...whats you rev limit gonna be?
yes exacly. its the revs. but more so power aswell. if you have a look at the graph it clearly shows all are ok up to 7k. and after that the vibration goes of the chart.
not saying the ross one isnt any good. just they dont say anywhere that i can see that they actually absorb the vibrations.
and as for powerbond. wel.. i will take a pik of the race one thats used in v8 ute racing on a gen3 with FACTORY rev limit with reduced power from retarded ignition.
there is a good 6 degree whip going on at the crank. the circlip that holds it together has a nice grove with witness marks showing exacly how much its shaking.
its really just an insurance. just like buying a set of conrods. for that power leval. they might not break. but if they do...
Al i was absolutely committed to getting an aftermarket damper and spoke to ross and powerbond. both told me that on an RB26/30 revved to 7500 max in a non competition car (ie no requirement for a certified damper) the standard one is as good as anything. powerbond even said that the standard one is better at reducing torsional vibration than some lighter afermarket ones.
Dave i can appreciate that the ATI damper reduces torsional vibration the degree of deflection on that graph curve would presumably not be applicable to all engines? I might well be missing something.
Paul if the stock pumps live OK to 7000 then the redline of over 7000 in the RB26 is a bit scary!
Regards
I intend to have the rev limiter, on the rb30det, set to 8000rpm but this all depends on the dyno graph. I am using a GT3076 (GT30R) turbo, which is actually the smallest recommended turbo for my engine, so if the power dips well before 8000rpm there is obviously no point in reving the engine that hard.
So why does a lightened flywheel cause more vibrations than a std one?
Does it still have an effect if it is balanced?
There is a 600hp ATI balancer, which is obviously cheaper than the 1000hp. I paid about $600 for my ATI 600hp balancer, as i do not intend to make more than 350rwkw on my car.
Ok now I'm confuzzled. ATI website shows a 500hp damper and a 600-1000 hp unit. I'm not aware of a 500 hp damper hence my question re cutting it fine for 350 rwkw.
Cheers
  • 3 months later...
Cheers
Sorry for the extremely late reply; unfortunately i didn't get any email notifications for this topic :D
Anyway, just checked the paperwork that came with my ATI balancer, as your comments raised concerns, but all is good.
From the ATI paperwork:
Street/drag use: 800hp MAX, replace every 10 years
Circuit use: - 400hp replace every 5yrs
Circuit use: - 400-600hp replace every 3yrs
Circuit use: - 600+hp replace annually
Since my car is a "weekend car" with the occational track/motokhana use, the smaller balancer will suit my purpose.
The way i look at it: These have to be better than the std balancer, so no need to worry about "cutting it fine" :)
    • bumping this post as im still having dramas, my fuel pick up is sitting on the bottom of the tank, my pump gets a constant 13 volts through a relay, my fuel pressure holds consistently without fluttering or dropping, yet as soon as im near half a tank of fuel my car starts fuel starving and leaning out, it cant be due to g force as it never pulls hard enough before it starts breaking up, any help would be much appreciated
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
