R32 Rb25de Head, Q45 Afm, Blitz Turbo Timer, R33 Gtr Parts, Apexi Suspension, Updated 21/1/08 Prices Dropped!
Hey all,
Got a lot of stuff I need to clear from the garage, I need room to work on my project! I’m open to reasonable offers on all parts..
R32 parts:
RB25DE head from a r33, . I am chasing $500 for it. Reasonable offers will be considered. Due to the weight freight will be expensive but I’m willing to arrange it at the buyers expense. Also have a RB30 S1 block for sale.
R33 Gtst Parts
Q45 afm 90mm as new condition $250
Rear seats complete (2 pieces) $80
Rear bar $40
Rear Tail lights, $80 each includes surrounds.
Power Window Switch Drivers side with surround $120 Series two only
Power window switch surround only $40
Drivers window side glass $80
R33 GTS-4 parts
Ignition barrel with rack and genuine Nissan key and all surrounds $200
6x rb25 coil packs with wiring loom and bridge from r33 series 1 $220
Boot lid black no spoiler r33 gts-4 coupe has sound deadening $120
RS-r springs for suspension $140
17 inch Chrome wheels almost new tyres suit 4 stud Nissan. Rears have good rubber fronts are worn. $400
R33 gts-4 rb25de manual gearbox 5 speed twin syncro, looks like the rb25det box with 4wd rear output shaft like a GTR box $400
R33 rear cradle does not have hicas from factory no extra weight of hicas or lock out bars, has better geometry for traction upgrade for 300zx or weight reduction for r33
this is for a bare cradle $200
R33 Vspec GTR Parts:
HKS camshafts in/ex 280 degree 10.2 lift were installed never used $700
Drivers door trim blue insert $50.00,
White exterior Power mirror $60
Standard rb26 twin turbo pipes from cooler to turbo $300 set
Apexi N1 rear coil overs $400, fitted for 40,000kms. no leaks or damage
Blitz full auto turbo timer $120
90mm high flowing cat $150
Nissan S13 Silvia parts
S13 silvia 3 inch catback exhaust VEILSIDE best sounding zorst and rare jasma plated has 2 dents can't be seen on car $440 ono
Misc Parts:
RB30 s1 block crankshaft head will sell cheap
bridgstone turanza er30 tyres x 4 205/55/r16.....6mm tread left on two 7mm on the other two cheap $ 80
Im open to reasonable offers. Need all this stuff gone ASAP I need the space to work on my car! All items are located in Sydneys west. Happy to post the small stuff and can arrange local delivery for a small fee.
Also got a 180sx for sale.. has a bit of damage PM me if interested
Cheers,
  • Replies 59
Can i grab the spoiler without bootlid, $350 (unless the boot will fit an S2 R33 GTST)
that is not just your awd controller.. its also got your active diff controller... the unit on top >;P
fyi
collin- will not fit an r33 gtst there will be issues with the floor pan.
mad gt4 - it was running in the gtr before it was removed.. and pm sent
The GTR box will fit in a RWD skyline just need a bit of modifying! Ive got a GTR box in a RWD 32. need custom tailshaft, customize the transfercase, modify the mounts in some cases. Spewing bout the box I would have grabbed it if it was for sale bout a month ago. just replaced my one and the new box I got aint nothing special either :D
thanks for the info mate.. much appeciated.
the box is much cheaper then a r33 gtst box. its of no use to me as I will be using my existing box for the rb26 conversion..
HI, would you happen to have the under bonnet carpet and the rear side bumper pods?
Sorry mate dont have either of them.. Bonnet lining will go with bonnet.
Hey mate,
How much for the steering wheel on its own? I dont need the other stuff.
Its out of a R33 Series two V Spec, cluster had 80,000 clicks on it. box spins freely, had little to no metal flakes in the oil when drained..
Cheers,
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
