on the way home from work tonight i was driving my gfs car.... heading away from the casino towards the albert park area and some asian guy in a Silver 33 with blue neons under his car and other ricey accesories pulled up at the lights next to me revving the hell out of his engine... had a zorst and running more boost from the guage i could see... ignored him at the lights for a while.. he kept revving it up.... so i thought... fark it... i'll see what this can do.
*click*
takes off traction control
*click*
puts it into power
left overdrive on...
lights go green and he plants it... slightly wet roads he starts spinning them up... i take off half throttle... haha im ahead... what a n00b p plater... we've travelled about 10ms now and im still ahead so i plant it to the floor... auto kicks down a gear... nose lifts... exhaust starts screaming like a male banshee with his balls in a squirell grip thru a 20" subby with the bass on +6!
bahahaha im pulling away from him... 100m later he isnt gaining so i slow down and start breaking... he keeps going lol yeah u keep going... i would too... how embarassing.
https://www.sau.com.au/forums/topic/18333-maybe-she-will-beat-me/
lol my mate has a soarer GT exactly the same as your gfs (in fact I think he's dragged it at some point in time...) remember? the one with the same rims as what you wanted? And his car hands some major ass out, and its pretty much the same as u'r gf's setup, so i dunno...
anyways... if you back out now i hereby proclaim you:
Inarkus Poultrous
Soarer auto g/b r insane i drove a mates and the instant u floor it, it reaches redline and doesnt even budge even between gears, smoothest auto ever !!! and hes doin 13.8's !!!!! Auto's r often underestimated, work it a bit, enuff coolin and u'll be beatin a lot of manuals on launch all u need is the power to back it up
lol so many times i'll get em on launch but they'll pass me by 3rd, sometimes in 2nd too, :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
