i had a look at buying them too. they look pretty good on that 34. but i deciding that i couldnt go past the model 5 look of the hijoin rims. plus never liked rims that have spokes that dont go all the way to edge of rim. like 3 piece, those drift Rs, etc. just that in 18s they look like 17s and 17s look like 16s. my 2 cents
i find that most of the jap wheels that i see are farken ugly, especially when they are black or blue, etc. for example i would never even consider putting on nismo lmgt1s, for the example i gave above plus they are down right fugly. sweet jap rims are avs model 5, 6 and kreuzer, r34 gtr, buddy club p1 racing, volk te37. but like tony said it comes down to the individual. if you like the rims, buy them.
i got Roh's on mine but Adrelines.
Those look ok but look more like something that would come standard with a ford or holden - good price tho - if u like them then u should go for them - they wont look ugly.
I saw these wheels in HPI mag i think (some mag) they looked a lot better in that photo.
I dont like the Drift R logo. A bit tryhard to ripoff the GTR logo in my opinion. Why not use some creativity and be original instead?
Thats a pretty lame criticism but it would put me off buying them so...
:zzz:
The above rims are VERY expensive. Buddy clubs are $5,000? GT-R rims are always CLASS.
Volks you know how expensive they are.
It is a bit unfair that you compare rims that are thousands to a cheap set of $1,200 rims.
But again no-one said SAU did not have expensive tastes ;)
T.
i was comparing them to the work meisters and nismo rims. Buddy clubs arent worth anywhere near that. maybe in 21s
even if i could afford them i dont know if i would go for the big brands. model 5s have been my favourite from the second i saw them, so... i bought some hijoin copies cause of the all the copies around i thought they were the closest. plus it was good that they were the cheapest :P
avs model 5s :whackit:
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
