cruise in nov
50 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey Brett, I was the guy in the Silver R32 GTR from Narre North. I would be keen to go for a run up there, great drive for photos too.
Also if you and a few other people wanna go for a cruise one night send us a PM, i am always up for it.
sweetsweet! ill run the mt buller idea past a few people and if we can get a few numbers ill try to organise sumthin!
will do if we are ever gunna head out for a drive, same with you im allways keen to head down the beach for a spin wen the weather starts warming up!
cheers man
brett
will do mate, how ever i live in nsw now so maby xmas time when im back home we can go for a cruise.
also just got a email back from andre at ingition and he has to conferm dates but looks like it will be the 17th guys.
every one pray he can make it
hey guys yea im still up for this to however ignition haven't got back to me yet so i dear say we will no be looking at next year. ill kep you posted. just rember if this did go ahad it would be one big cruse and take time to orgonise
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
