OK before you perthies start tellin me to go to my own section :)
I wanna get perth numberplates cos they're l33t and long.
Also since I'm planning on doing a widebody conversion for the R32 I'm bringing down, I wanna get Phat Ass or sumfin similar to that.
What's the rules for gettin the plate, do you have to do a yearly renewal, does the car have to have a WA rego, any rules for rego, do you have to do yearly inspections?
Please advice and no whoring.
oh and no starwars porn...
https://www.sau.com.au/forums/topic/18338-wa-numberplates/
btw you know if you guys get 20 ppl together you can get WA numberplates with a "sporting club" logo on it. All you gotta do is have an Association number or ABN. I reckon you guys should get SAU WA numberplates, that'd be uber cool.
https://www.sau.com.au/forums/topic/18338-wa-numberplates/#findComment-383520
yeah but the sporting club ones are the type of plates the WA governement intends to lease to u so u pay every year to have the plate.
what do u mean no :) porn thats the best bit.
anyways all u need to do is apply for the plates and have them sent to ur nearest licensing centre. seeing your in wa i don't know how it would work.
you don't have to put them on a car staight away but you have to put them on a registered car. they hold them at the licensing centre while ur waiting for a car to put them on
https://www.sau.com.au/forums/topic/18338-wa-numberplates/#findComment-383831
do I need a WA registered car? If I do, is it possible to register the car once and then jus mail in the registration renewal. like in VIC?
If I don't need a WA rego'd car, then I'mma gettin myself a numberplate asap.
https://www.sau.com.au/forums/topic/18338-wa-numberplates/#findComment-383882
It goes like this (i used to be an licensing clerk) u wont be able to keep them for long if your car is in another state - i think its 3 months and then it has to have the plates handed in and the car licensed in whatever state your in and licensed with those plates.
Sorry.
https://www.sau.com.au/forums/topic/18338-wa-numberplates/#findComment-384314
yes they can hold plates for 3 years - but one of the guys in the eastern states wants WA plates on his car - The car must be licensed with a WA address and can have an Eastern States postal address - but yes the car has to be present in the state of license. If he was to take his car back to the east with WA plates on it then he could keep them for 3 months then they would have to be handed in and the car pitted and licensed in his own state ;)
https://www.sau.com.au/forums/topic/18338-wa-numberplates/#findComment-385379
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
