i hooked up my amp/subbies today
and the amp wont turn on
i have the cable from battery to amp via a fuse
an earth from amp to bolt in car boot
rca cables all connected
remote controll connection connected
i start up the car
amp wont turn on :)
chance of a faulty amp perhaps :S?
https://www.sau.com.au/forums/topic/183408-system-isnt-working/
When I hooked up my amp and sub it was working fine. Went for my first drive with it in and it was cutting out every now and then. I checked the fuse for the amps power wire and the fuse was a little loose in the holder at one end. I was able to just squash the ends in and now it bites down hard on the fuse and haven't had a prob since.
  • 7 months later...
I have a similar issue at present.
I have a Kenwood KAC-8103D 1000Watt 2 channel amp and i can't get the thing to start when the headunit turns on.
Heres the weird bit;
I work at a school so I have access to cool stuff in the science lab like 12volt power supplies. I hooked one of these up the amp and then bridged the power and remote together to get it to switch on. The power led flashes. Hooked up a voltmeter (cheapy science one but does the job) and it sits ib about 11-11.5 volts when the light is on and then jumps up to 12.5 volts when the light goes out.
Thinking this was strange, i went and got another power supply and connected it directly to the remote wire and now the power led stays on solid. I dunno how I am going to overcome this in the car as there is only one power source.
Something else that got my attention is that the amp WILL NOT run when I set the voltage on the power supply to 12volts or 10volts, and will only run when the power supply is set to 8volts... Also the amp will turn on when the remote wire is set at 2volts.
I think my amp may be playing silly buggers with me, but thats what i get when I buy the amp from a pawn broker.
i start up the car
amp wont turn on :down:
I dont think this is a fault amp, but hey i could be wrong. Id check to make sure that your earthed correctly. If that isnt the problem id check to make sure that there is power getting to the amp. If that doesnt work, check the fuse. If that dont work go to the place where u brought it from and get them to install it. Also read ur warrenty... little tip.
hey man, have you tried connecting a manual switch to the amp instead of running the singal through the remote wire just run a manual switch that can be turned on manualy by yourself.. and see if that works.
niran
Ok, hooked the amp up just to power and bridged the power and remote to turn it on. And still nothing. Amp flashed and made a ticking noise. Then the light started blinking more rapidly without the ticking noise.
Moved the earth to the another point in the car, where the battery is also earthing to so i don't think its an earthing problem.
We also tried the amp in a working setup and had the same issues.
*Never buys amps from pawn broker again*
Also, not quite sure on what gauge of wiring is there. There is one big thick one running from the battery into a 2 distrabution block (to power 2 amps) and the wire from them is a bit thinner. Same wire I have seen used in every other system i've seen
Edited by ShayneJ
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
