Sorry Guys . If I knew it was going to cause all this I would've said nothing
I've always been interested in the local build up's and as you said anthony we are all skyline owners from newy.
I will probably never be able to tune as many cars as you have effie but i am trying to expand my knowledge of tuning as much as possible so I thought it might be cool to see this vehicle getting the numbers dialed in ..
I thought wrong
Edited by SATO GTS
  • Replies 682
Hey i appreciate your interest Kyle...but where do we draw the line. Id like to see you and catch up but the less people at the workshop the better. Ive got dozen's of people/mates who want to come and watch but have told them id rather they don't come over. Come down when we race and pit with us etc..bit more excitement and more to see/watch.
I thought wrong
in his defense though.. it does a get a bit how you doin when there are too many people hanging around.. its harder to tune a car when people are asking questions and stuff. It happens with me all the time as well. He is the owner of the car and its his choice.
I should be tuning my car on sunday or maybe tomorrow arvo.. you can come watch me if you like :)
yeah it is hard we had a $250,000 rod on the dyno with a 80k engine.... concentration, space and quiet when you need it are paramount to getting a good result. I prefer to keep bystanders on these type of jobs to a minimum (owner, tuner, engine dyno or engine builder only)
For general customers who are happy to have freinds watch thier car on the dyno... no dramas but now and again we do have closed tuning sessions also.
Edited by URAS
Had a few hours of tuning 1pm till 4pm got it all mapped up to 7000rpm. Took our time making sure all was perfect at each load cell tuned. Guilt-Toy did a stellar job tuning such a big car, his easy does it, cautious approach was excellent, no 'rip tear bust' here. We had Mark linked up to the laptop with his computer at his shop in QLD keeping an eye on things and helping out when it was needed.
We were having a little issue with oil leaking from the turbo drain flange not being tight or maybe not having a gasket fitted. As we were stepping up the RPM the leaking oil was getting worse so instead of having an oil fire we decided to pack it up.
Edited by DiRTgarage
Yeah it was a long day.. Lots of work was done to the car to prepare it for the Dyno. I was pretty fussy and was starting to annoy paul with some of the requests before i was ready to tune it. Everything got sorted out and we only had a few hours left to tune it.
This car is awesome. So tough its just amazing how good the engine is, you can tell that it was built by a true professional *cough paul Red R Racing cough* lol :domokun:
The gearbox took a bit to get used too, I connected Mark @ Godzilla Motorsport to have a look at the map and give it a once over before going over 4000rpm and we had a couple of things that needed to be changed, after Mark was happy with the setup it was smooth sailing all the way.. There was only a couple of videos taken because Paul was too busy making sure the turbo drain was not leaking, just as we were ready to start power runs it was decided to stop and fix the issue before taking the revs up anymore.
Here are some pics, and Videos
Thanks again Guilt-Toy...Both Mark and I were impressed with your work...well done.
How much does it sound like a jet in the vid's?
Power tuning next Saturday...cannot wait.
Thanks.. it has been great working with Mr Godzilla himself.. Was a good day :domokun:
Sounded even more like a jet in real life... I sooo want one of these turbo's!!
$5565.81 not including freight and duty plus $1100 to modify it to T62 spec...do you want me to order you one?
Yeah no probs.. Set me up on a monthly payment plan.. I will pay you back $100 a month :domokun:
Id prefer to finish your car Friday night so i can spend sat on mine seeing i missed out on working on my car today.
Im keen...one less sleep for me to wait...lol
Ill ring HKS now and order you one. I know where there is a genuine T62 for $6500 in Aust.
    • TBH, it sounds like the threads on the bolt are fubar in a specific section. Most likely as you've been working it back and forth it has torn threads out, as you loosen the bolt, this section enters the nut, now you're spinning a round shaft inside the nut, there's no threads here.   Use something similar to a claw on a hammer that will fit either side of the bolt head and try to apply downward force while also undoing it. The idea is to attempt to catch a thread, or just rip the f**ker out. Caution on ripping out, as it could bend/maime/mangle what the captive nut attaches to. If the captive nut is actually okay, you could do the dirty part of cutting the head off the bolt, then cut a slit in the end of the thread that's now exposed and then screw it up and into the area the captive nut is until it falls out the other side. However, this does risk the remainder of the bolt rusting over time and damaging near the captive nut and also making it rust. However, so can cutting pieces of panel work out to access this area if you don't reseal it properly.
    • Well, every piece of information on that part when you track it back to Nitto says it's for a KIT of theirs. It is also designed thicker to be stronger. And they speak about a specific harmonic balancer bolt they supply for the whole setup.
    • Techniques for removing stuck bolts are: hitting the bolt head with a hammer, heating the bolt to red hot then letting it cool and working it back and forth like you are already doing. AFAIK the idea is to try to crush whatever material is stuck between the threads (and heat also melts locktite but that's almost certainly not relevant in this case).
    • Yuh, I think it works with the Nitto gear only. I presume that you're not also using the Nitto gear? Watch the video. Compare the interface between the Nitto gear and washer (on the gear side) vs the stocker and decide if you think the Nitto gear is different from stock there.
    • Liking the new charger, battery all good (I think).   Also like how you can put it in power supply mode too. Will troubleshoot with that sometime soon.
