cant wait to get home and check the vids..
fatz/kyle.... can you tune some compression into my little 20?? and tune the knocking noise out of it?? haha i will supply you any beer you want "aslong as its a corona"
big restecp to dirt and guiltoy.
  • Replies 682
To be honest i was worried when i first jumped in the car, set the ignition timing without even having to turn the CAS, Mr Dirt opens the car door and says what about the timing, i explained to him we don't need to touch the CAS, all done on the software i could see he was a little worried too, little did he realise this is no power FC.. The Vi-Pec V88 was starting to impress him before the wheels were even turning on the Dyno which was funny, he spent the last 12 months talking up this ecu and then forgot how good it actualy was :laugh:
After about 5 mins, Paul comes to the door and just watched the auto tune in progress, i looked up to look at him and then he smiled, looked at the pc and in green read "target reached"
After about 15 minutes i was checking the iat, checking the ect and the oil temp's and everything was fine.. It was then I realise i was not tuning a car built in someone's back yard, always checking stuff for issues or over heating issues, this thing did not go over 85deg and was just running for the most constant time i have ever run a car on a dyno, when changing gears and hearing that box crack the gears i realised I was tuning a Properly Built Race Car that was tough as nails then my confidence started to come back to me and we managed to map the whole car from 0 to 7000rpm in about a hour and a bit..
We ran out of time because Wayne @ Hunter All Wheel Dyno wanted to go home cos he was there all day for us, what a champion!
More tuning to be done this weekend, Twoogle & Guilt-Toy should be ready for power cruise on saturday i hope.
Bring on the power runs!!! 500rwkw & 400rwkw the mission for this weekend!
To be honest i was worried when i first jumped in the car, set the ignition timing without even having to turn the CAS, Mr Dirt opens the car door and says what about the timing, i explained to him we don't need to touch the CAS, all done on the software i could see he was a little worried too, little did he realise this is no power FC.. The Vi-Pec V88 was starting to impress him before the wheels were even turning on the Dyno which was funny, he spent the last 12 months talking up this ecu and then forgot how good it actualy was :D
Ever thought of becoming a writer Anthony? :laugh:
Surely it will go over 500awkw, hell, the little GTRS's did that so the single should manage it easy
of course it will...but flogging an engine from the get go on pump fuel is not my thing.
Edited by DiRTgarage
Cool cool
'Little' GT-RS's? :)
In relation to the single :D
They've got stock like response on my GTR though ;)
To be honest i was worried when i first jumped in the car, set the ignition timing without even having to turn the CAS, Mr Dirt opens the car door and says what about the timing, i explained to him we don't need to touch the CAS, all done on the software i could see he was a little worried too, little did he realise this is no power FC.. The Vi-Pec V88 was starting to impress him before the wheels were even turning on the Dyno which was funny, he spent the last 12 months talking up this ecu and then forgot how good it actualy was :P
was that just WOT or everything inbetween?
The whole map from 500rpm to 7000rpm has been mapped from the little amount of vacume that this engine gets to full throttle.
Power runs is the next step from here to map the rest of the car and clean up.
Should only be a hour dyno work + 15 mins on the street to get it right. I am not in a hurry with this car. If it takes longer then so be it.
well theres some pretty damn good positives
next tuning sess. are you able to get afr and timing plots vs rpm?
vacuum...what vacuum? I wasn't aware my engine produced vacuum.
Yeah the Vi-Pec has some awesome software / hardware loging capabilities. You can record / play back the run and it has 4mb of internal loging which logs the data even when the laptop is not connected which is enough for a track day or 2 worth of data.
Yes. It does venture into vaccume when cruising, its only on idle where there is no vacume :P
it's a V8 isn't it?
nah thats my car.. and only in a place full of yobbo's :P
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
