Item: s13 Silvia, 91', 5sp manual, SR20 non turbo, LOW KMS!!!
Website: www.carsales.com.au rego no. 695 KBQ
Item Condition: GC, female driver, always garaged
Reason for Selling: need money urgently for investment
Price and Payment Conditions: $7999 o.n.o
Extra Info: colour: Champagne gold with grey two tone
Pictures: pictures up tomorrow or on carsales, rego no. 695 KBQ
Contact Details: kimi - 0432 191 349 or [email protected] or pm me ^^
NEEDS TO GO THIS WEEK, sr20de, 5 speed manual, non turbo, very good handling, good for cruising, and fuel efficient. excellent car for p platers with new laws.
Exterior:
it has an after market sports exhaust with custom canon, alloy wheels, new lowered suspension - King Springs in the front and Rsr's at the back, radiator professionally rebuilt, yellow silicon hoses in engine bay, just recently services - new oil filter, always looked after, fuel injector cleaner used every 10,000 kms, recent gearbox oil change, timing chain replaced around 10,000ks ago. has new 2nd hand front gaurd due to my brother denting it with his bike, atm it has 15inch enkeis but will sell with stock sr rims.
interior:
in good condition, kenwood cd player with 6x9 upgraded indoor speakers, aftermarket watertemp and volts gauges in custom made din, alarm, remote central locking and alarm, power windows and mirrors, power steering, all electrics in working order
never been thrashed nor over heated, always warmed up before driving, and cooled down before turning off, never had trouble with cold starts
female owner!
selling due to new job, and need funds for investment.
PRICE DROP $7999 neg.
Edited by kimsr324dr
https://www.sau.com.au/forums/topic/183570-s13-silvia-sr20-manual-non-turbo/
  • 3 weeks later...
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
