hi guys.. my drivers side indicator is flashing more quickly than passenger side which i assume is not grounded properly.. where do i check grounding for this..
also my speedo cluster lighting is faint and randomly lights on/off.. is this related to my grounding issue..
my headlight sometimes also does not alway turns on first time.. i have to turn it off and on again for it start displaying.. any ideas..
https://www.sau.com.au/forums/topic/183673-electrical-problems/
roger that.. i have taken the indicators and cluster apart and swapped some globes around.. still my lights on the speedo cluster and centre gauges flicker
No, checked all the indicator bulbs?
  • 4 weeks later...
well sorta.. if i play around with cables.. it seems to fix the issue.. by play i mean twist it around.. the plugs that connect into the blinker looks brittle and has black grit over it.. is it easy to source replacement plugs etc.. it is stable for now..
I think on that plug you should be able to prise it open and reuse it. Double check the globe, I had the same issue and thats what it was, the coil filament was broken but still touching, so it would work intermittently or whenever i thumped it. Plugs are plentyfull off wrecked skylines on ebay. You could also try pulling out the globe and cleaning the contacts on the inside. They usually get electrolite/oxides buildup when theres a poor earth
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
