Hey Tex... I told you I would have a suprise for you on the forums soon... this is a car that my Girlfriends Uncle looks after. (due to his large garage!
Hope you like them mate!!!
Also, Can I give you that DV tape and get you to brun it to a cd or something for me?
Cheers,
Dan.
https://www.sau.com.au/forums/topic/18373-for-tex/
Hmm, nice Dan, it looks in quite good nick, original, but in good nick. Did you realise it was a Buick when you were telling me about it last week?
As for the DV burning to CD thing, not so simple, it would have to be converted to another format first because DV takes about 14gig for one hour of DV format video. I'll sort something out, I'll let you know when I've got the software side of things happening properly, as I'm still ironing some creases out.
Andrew, EC lap times? Hmm, prolly about 4 minutes I'd guess. Might have to bring mine along when it's finished, and get an idea, eh? Do they even have a group G? :D
https://www.sau.com.au/forums/topic/18373-for-tex/#findComment-384818
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
