DONE TO DEATH!!!
What hasnt been done to a r33 skyline!!!
1996 so its 11 years old so no doubt everything has been done.
But i was looking at a BN rear bar and skirts, with a trust front. now any kitted line has that exact thing!
what hasnt been done to death?
Am looking at fenders and a bonnet but what kit should go wid it?
wanna stand out as much as possibale!
help!
https://www.sau.com.au/forums/topic/184072-kits-r33-gtst-series-2/
Maybe theres a reason why.. :whistling:
That red 33- the kit doesnt seem to fit properly either.. also its for a series 1!!
I will tell you what you dont see everyday here in aus.. Eastbear genuine stuff!! go all out and get eastbear stuff!!
Remember i sent you a link with every kit possible in japan.. Did you even go thru it?
Problem with BN kits is that it has WAY too much flare, you need a decent set of wheels to pull it off. Most people buy the kit and left with no money for the deep dish wheels so it ends up looking very awkward.
Maybe theres a reason why.. :(
which link???
Heres the link..
hope this may help:
http://www.takakaira.co.jp/aerokits/aerokitindex.asp
For nissan: http://www.takakaira.co.jp/aerokits/aeroki...emenu.asp?cat=4
Edited by siddr20
Maybe theres a reason why.. ;)
have to agree that was a poor pic, if i find the better ones i post them up!
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
