i guess it depends where u go.........i got mine done through tint-a-car here in adelaide and i think it cost 350 or somethin like that was only the side and back windows though, and that was 4 the darkest legal tint
https://www.sau.com.au/forums/topic/184190-window-tint/#findComment-3335363
I know a tinter in Coffs, will charge you max 220 whole car (ie, 2 skyline, not bus) ost big name joints will charge you through the roof, and use the same film as the cheaper guys. If anyones interested, pm me.
https://www.sau.com.au/forums/topic/184190-window-tint/#findComment-3338699
there are some tinters that you would not go to....some that put dents on ones r33 then do not own up to it.
my advise is to go to one that people on sau here used.....for example, here in vic, most have used this one guy - great price, great work....
the other place i can recommend is premier tint......
https://www.sau.com.au/forums/topic/184190-window-tint/#findComment-3342434
got mine done the other day darkest legal for $300 mobile service, but i said i would come to him so got it for $250 but then I decided to do the sunroof as well so was $290 all up. The guy was really professional and did a good job. Highly recommended. The tint is really reflective so at certain angles it looks quite dark.
QLD, tintmart at Geebung
https://www.sau.com.au/forums/topic/184190-window-tint/#findComment-3359852
can anyone tell me if they know of anyone or anywhere that supplys reflective/chrome/mirror tint...
im after purple chrome/mirror tint. iv seen it on show cars and have rang many places, but they say they dont supply it or fit it because its illegal.
(iv also seen it in a gold colour)
https://www.sau.com.au/forums/topic/184190-window-tint/#findComment-3359884
I've found most of those cars are normally imported with the tint on but there must be someone who does it locally. Im after a guy to do mine with the glass out and i wanna go a little darker than legal. 30% isn't quite enough. Anyone in Brisbane you guys can recommend?
Deren
https://www.sau.com.au/forums/topic/184190-window-tint/#findComment-3360247
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
