Tryna suss a hard pipe kit for the 33GTST. Any one know a ball park figure and probs best place to suss one?
alsooo lookin at sectioning my air intake from the rest of the engine bay jus to stop prevent runnin hot under hood air through it. Whats ideas on that?!icon2.gif
Brock
https://www.sau.com.au/forums/topic/184482-hard-pip-kit/
The N/A intake pipe is very different to the turbo one. On the NA its prob best to leave the intake piping alone and just get a high flow panel filter or if you like a pod with a cold air in take. By changing the intake pipe you are losing the box that is connected to the pipe. This box is there for two reasons.
1. To quiet down induction noise. (who really cares)
2. It is a box that has been made with a calculated volume to give best response. In other words, this box fills up and holds air really close to your engine so as soon as its needed, its right there and doesn't need to pass through the filter etc.
The second reason will tell you that changing your intake pipe will actually decrease your response.
I do agree though. A nice stainless pipe would look much better :D but it unfortunately comes with a negative result
https://www.sau.com.au/forums/topic/184482-hard-pip-kit/#findComment-3340867
Ah cheers,
sigh, i was looking forward to a nice shiney pipe.
mates have got commodores and the like and say it flows better than the plactice pipe..
but didnt take into account that box thing that looks like a block of chocolate.
Im running a pod atm but i need some sort of housing as it's just sucking in hot air from the engine bay,
would it be better to buy one of those plastic shield things you see at supercheap or to try and re-route the piping to the front of your kit someplace?
:D
https://www.sau.com.au/forums/topic/184482-hard-pip-kit/#findComment-3341192
That apply for Turboed too???
Also my mate that works for nissan says the hard pipe will give you a nicer flutter too, is thus truue?
https://www.sau.com.au/forums/topic/184482-hard-pip-kit/#findComment-3342086
Cheeers
Its not the same for turbo models. You'll notice tiurbo models don't even have this box at all. The reason for this is a turbo provides forced induction. This means that the response is forced. While there may be lag before the turbo spools, the response is a lot bigger when a turbo is forcing air down the intake pipe.
Any change to your intake will change the sound of the flutter, bov and induction noise. It all comes down to preference I guess
Ah cheers,
I agree, the shiney piping looks hot, but not worth while in this case. Have a look at a stocko commodore intake pipe and then compare it to the aftermarket one your friend has. The intake setup on a commodore is totally different to an RB.
Definately get a cold air intake for your pod. It will make a big difference. Some people have even said their performance drops by having a pod open in the engine bay and went back to the stock air box. A cold air intake will fix this. Get something made from stainless. It will sheild the heat much better than a plastic sheild. And piping to the front of your kit would be good too.
You will notice indents under your air filter that look like they forgot to cut two holes. This is where the turbo models piping for their side mount intercoolers run through. You can cut a hole there to feed your air filter.
https://www.sau.com.au/forums/topic/184482-hard-pip-kit/#findComment-3342692
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
