Hey
My car is pretty stock, came from Japan about 4 weeks ago.
Only engine modifications it has is a back exhaust and pod filter.
Basically there is no rev limiter? I have rev'd it to 8,000rpm on occasions and backed off as it didn't stop at a limiter?
Red line starts at 7,500 if I am not wrong, and it should be limited at 7,800 if I am not mistaken?
I have spoken to a few other RB20 owners and they have also had the same issue. I guess the question I am asking is, did R32 RB20DET come out with a rev limiter?
I haven't checked the ECU yet, but I doubt it would have been altered as the car is very stock.. But what would I be looking for that would show the rev limiter has been removed?
Any input would be appreciated.
Thanks in advance,
Abu
Edited by abu
https://www.sau.com.au/forums/topic/184518-rb20det-rev-limiter/
  • Replies 60
my mates rb20 revs past 8000 rpm too! he is scared to over rev it! he thinks there was no limiter so 8200 sounds possible
Yeah its very weird!
I usually rev my cars hard, but I actually really like this R32 and I'm looking after it haha
I don't want to be reving it past past recommended redline!
Has anyone experienced or seen a RB20 with a rev limiter, on standard ECU?
Edited by abu
It may be "apparently" higher because the spring on the tacho needle is getting a bit "soft", and letting the needle spin further than it should.
I've noticed the tacho readout on my Wolf handset is less than the tacho in the instrument cluster.
yep mine was 8,200 standard auto ecu
bashed it every monday night for 3 months making 230rwkw
no probs
pretty sure its still going now
8,200 far out. I would never rev it that hard.. well..
It struggles to rev kinda past 5,500 - 6,000 rpm due to being on standard turbo, stock intcooler and only having a cat back exhaust.
Once I get the turbo back exhaust on, cooler and bigger turbo on, with the WOLF tuned then I will rev it to that ;)
Oh thats interesting..
No idea man, wont be able to check that until I get my WOLF in and tuned I guess, or I guess until it gets onto a dyno.
Edited by abu
7,800 is the factory,
mine had an auto box now a manual box, hasnt ever changed....i have it chiped and its still the same only the speed limited was put a fair bit higher.
it shouldnt have a problem reving that high even on stock turbo....just that you wont get stuff all power up there, so its kinda pointless to rev it that high. if you have an aftermarket turbo then go for it.
I can confirm this also.
the standard tacho is inaccurate. there is indeed a 7500 rpm limit with a hard cut at 7800. the tacho is almost 10% out. so 7500 + 10% = 8250 ;)
Is that right. Whats the reason for it being out, like where they released out from factory?
I haven't managed to actually hit limiter, even in the wet when having a bit of fun, but I tend to be cautious about how high its reving.
Ohh ok thanks man.
Yeah no point reving it that hard unless you get power that high, which you wont on standard turbo. I don't tend to rev it past 6,500rpm as it is now as it beings to struggle.
But once I get it tuned with the WOLF I will get the limiter set to about 7,800 rpm.
With my standard ecu, mine hits the limite at 8300 but my RSM says 7600ish at the time dont hold it long enough to write it down ;)
8,300 rpm damn, thats high. Weird how they are out so much hey?
LOL @ dont hold it long enough to write it down.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
