I own a GTST Series 2 R33.
Does anyone own one aswell and is running a slide highflow?
Compared to stock turbo how much laggier is it?
What sort of kws u getting out of it?
How long u had it on your car for?
Mods Include -
POD
FMIC
Power FC & Controller
Apexi Boost Controller
Soon to have 555c injectors
Would i need anything else? would it puch 260kws on a SAFE tune?
Thanks
https://www.sau.com.au/forums/topic/184705-slides-highflows/
My cousin has one on his R33, just with cooler, turbo back exhaust.
Doesn't seem muc laggier, only a little.
Pulls very strong on boost all the way up to red line. He has had it for at least a few thousand km's with no issues.
I also want to get one for my R32, but SLIDE doesn't make any high flows anymore..
VG30 max over size high flow would be better for 260rwkw and above.
Edited by abu
But GCG do Ball Bearing not Journal... so itll spool like 100-200rpm faster or someshit like that.
If you ask GCG maybe theyll do a Journal Bearing for cheaper.
Edited by Pauly33GTS-t
Yep same problem here.
Not I am also undecided on what to get.
Just a a HKS2530 or something similar to that, maybe even a HKSGTRS.
yer my problem is i dont know enough about turbos to make a good decision!
If you are only looking to make 300 rwkw or less i would vote the GTRS or the GT28rs hands down.
Anything over this and you would be looking at something like the GT3071 or something similar.
From what i have read these are the two best turbo's for around the 300 rwkw mark without losing too much driveabiolity as an everyday car.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
