hi there, yes i have searched, but only found one comment saying that they wont fit, just wanted definitive confirmation
the guy selling the coilovers (r33 gts4 tein SS aus spec) says they'll fit, BEL garage says they'll fit.
croydon, UAS, justjap say they wont fit, and some workshops are unsure
i only need to know if the rears will fit
need to know by tonight
cheers in advance
  • 4 weeks later...
cheers in advance
im not 100%, but i would assumed they won't fit because the gts4 is awd, so you would assumed it would be the same as the gtr suspension.
here is a photo of
gtst coilovers
and
gtr coilovers
As you can see only the rears are difference, best bet is to look under your car at the rear and you should be able to see what the suspension looks like then compare it to the above photos
Edited by [Michael]
  • 5 months later...
so does this mean i can go and buy some coilover kits for a r33 GTST to directly bolt onto my r33 GTS4 ?!?!
i.e, r33 gtst, gts4 use the exact same suspension kits?
Edited by OoskylineoO
No. They will "fit" but they won't "work". The front shocks are much shorter on the 4wd's due to the higher placement of the lower mount which is required to clear the front drive shafts. The front spring rate, and the damper rates, are too high for a 2wd due to the extra weight (~12%) that a 4wd carries over the front wheels.
BTW, you can't use a GTR kit either as their rear shocks have forks for the bottom mounts, not eyes like GTST's and GTS4's.
Cheers
Gary
i read in another similar thread that some1 had r32?, r33? gtr front pair adjustable coilovers and a pair of rear adjustable r33 gtst coilovers and worked fine. Is there any major or long term problems with this set up?
SK, do you have a set of adjustable coilovers for r33 gts4?, if so how much do they go for?
i hav a set of teins for a gts4 if your interested. pritty much brand new. lookin for round da 750 mark for them
These are the Group Buy full kit details, over 160 kits sold to happy Skyliners, read the reviews in the various Group Buy threads
Nissan Skyline
R33GTS4
Front Springs $144.00
Rear Springs $144.00
Front Bilstein Shocks $588.00
Rear Bilstein Shocks $588.00
BNF27Z Front stabiliser bar $219.00
BNR11XXZ Rear stabiliser bar $219.00
KCA332 Caster Kit $110.00
KCA348 Front Camber kit $183.00
KCA347 Rear Camber Kit $123.00
KCA349 Rear Subframe alignment kit $105.00
W0921 Bump Stop & Dust Cover $102.00
Freight $-
Sub Total $2,525.00
Less extra 5% $126.25
Total $2,398.75
Payment is required at the time of placing the order.
I can do credit card, just PM me the details, or bank transfer
Account Name Jamex Australia
Bank StGeorge Bank
BSB 332-086
Account No 551029694
PM me the transfer receipt number and we are underway.
Please don't forget to send me full name and address for the order plus a contact phone number for the courier in case they need directions or instructions if no one is home.
Springs are usually in stock at Redranger
Bilstein takes 1-2 working days to machine the additional circlip grooves
Bushes are usually in stock at Redranger
Stabiliser bars take 4-5 working days to make as we do not keep stock of the unique Group Buy bars
Delivery is via Star Track Express and usually takes 1-2 working days to anywhere in Australia.
I will PM you the con note number as soon as it is issued it that way you can track the delivery on the Star Track web site.
Skylines NEVER have enough caster, that's why they wander at speed, are reluctant to turn in and have poor steering feel. Hence the need for adjustable caster (radius rod) bushes.
The standard rear subframe bushes are very soft, silicone filled. They are soft when new and do wear over time until they finally leak. The rear subframe alignment kit supplements the standard bushes, stops the subframe from flopping around and at the same time give some adjustment of the rear squat. This allows for improvement in the rear traction.
If you lower it and don‘t correct the excessive negative camber you will suffer from rapid tyre wear, as well as reduced traction for handling, braking and accelerating.
For camber kits, please keep the following in mind when lowering yours. This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
The standard suspension bushes are very soft. They are soft when new and do wear over time until they finally split and fail completely. The Whiteline bushes are obviously new plus they are up to 75% stiffer than new standard bushes. This stops the suspension arms from flopping around and dynamically changing the camber, toe and caster settings over every bump and ripple in the road. This is especially noticeable when cornering loads are applied, hence you get a noticeable improvement in tyre contact patch and hence traction.
I have included a couple of kits of bump stop/dust covers as the R33's are getting on now and most times the standard ones are stuffed. It saves a couple of days waiting around to get them delivered when you find the standard ones are unusable.
The Group Buy Bilsteins have additional circlip grooves added so you can set the height you want before you fit them. There are 6 grooves 8 mm apart and I can tell you the height that you will get from each groove. Keep in mind that GTS4's handle best around 355 mm front and 345 mm rear (centre of wheel to guard).
Adjustable shocks are only worthwhile if you know what you are doing with the adjustments. Most of the time shocks have adjustment to cover up for their unsophisticated valving. This means they only work in a small range of conditions and so they have to have the adjustment. Bilsteins have very sophisticated valving and consequently have a large window that they operate well in. Simply put, they don't need adjusting. Plus I have selected the valving to suite the Group Buy kit.
I think that about covers it, if you have any questions please just ask
Cheers
Gary
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
