Item: Stainless Steel Dump/Front Pipe with screamer pipe to suit RB.
Condition: Perfect condition, used for just about 5 months on my car
Other Info: Note the length of the screamer pipe, long enough to stay away from anything on the engine bay.
Also note the pipe going right into the dump outlet to minimize turbulence there.
All in all good design,
Reason for Sale: I have a new external wastegated set up. :blink:
Location: Adelaide, will deliver anywhere in OZ for an extra $10
Price: SOLD
Pictures:
post-18416-1189765719_thumb.jpg post-18416-1189765735_thumb.jpg post-18416-1189765751_thumb.jpg post-18416-1189765765_thumb.jpg
Cheers
Ric
Edited by Richo
https://www.sau.com.au/forums/topic/185044-stainless-steel-dumpfront-pipe/
i had always thought a front pipe was the pipe between a dump pipe (wat u have here, only instead of being a spilit dump, ur wastgate side has been chopped off therefore making it a screamer pipe) and the cat-converter?
hmm, not sure now, confused.
What you say makes sense, perhaps this is only the Split Dump with Screamer to bolt onto your Front pipe, would that be correct??
anyway, buy it ,chuck it on, and hang on to your knickers :worship:
PM replied too.
ahah yea maybe screamer just welded onto the flange as well..no worries man was after a front pipe. GL with sale (urs looks hot btw my screamer is only down to the connecting flange :worship:
hey mate
so if i remove my existing dump this will replace it hassle free? pretty keen dude
wouldnt happen to have a pic of it fitted?
cheers
Hey mate
yes it replaces the existing dump, its pretty straight forward really, a bit tight space wise to install but youll get it there, if not you can get someone else to do it for you.
No pics of it installed im afraid.
Cheers
Ric
hey mate
cheers
mate i'll be putting mine on in a coupla days so will have some pics to show wat it looks like!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
