  • Replies 67
Well 370rwkw - pretty much your usual RB26 build.
R33 GTR crank (or 32 with collar)
Stock rods with decent rod bolts
Forged Pistons
Usual pretting/maching and so on
HKS2530 or similar
Bit of a head tidy up
Injectors
AFMs
ECU
Exhaust/Dumps
Clutch/gearbox (if you dont already have)
Probably freshen the diff
Suspension/brake upgrages
Replace all hoses around the motor etc etc.
Your easily looking at 30k spending, if not more.
Plenty of info on ~370rwkw RB26's lots of em around.
https://www.sau.com.au/forums/topic/185101-500hp-atw-rb26/#findComment-3350782
The usual forged bottom end; no real need for major head mods - just a clean up when you fit Tomei poncams; T04Z or GTSS or GTRS's; power fc, 700cc+ injectors,bigger fuel pump; oil mods won't hurt and also a decent oil pump like JUN, HKS, Trust etc
There will be other requirements, but these are the basics.
https://www.sau.com.au/forums/topic/185101-500hp-atw-rb26/#findComment-3351066
You don't really need twin highmounts to achieve the power you are after, unless you just want them for the sake of having them. My twin 2835's made a lazy 411rwkw on 1.1 bar, but the abovementioned turbos in previous posts can easily make the power you need, which is plenty for a street RWD car.
https://www.sau.com.au/forums/topic/185101-500hp-atw-rb26/#findComment-3354965
ye, i too would advise against high-mount.
While it looks good (depending on turbo choice), its not as functional when there is a wide range of products out there that easily fit your goal, and use the stock gear tahts tried and proven.
Highmounts just means massive cost, for no better gain. And well... 2530's really arent that impressive (size wise), so high mounted from the looks, they would be so-so
Are you after the show aspect here mainly?
https://www.sau.com.au/forums/topic/185101-500hp-atw-rb26/#findComment-3354981
R33 box will take 370rwkw no problem.
Main reason for that is you wont have any traction no matter what you do :ninja:
You'll be fine IMO in RWD with a R33 box. I raced mine with 370rwkw 3-4 big days (20+ runs each time) and cant say i noticed any issues... but then i didnt have one iota of traction :mellow:
https://www.sau.com.au/forums/topic/185101-500hp-atw-rb26/#findComment-3355614
twin high mounts would be a massive waste as the turbs would be fairly decent sized (unless u had plans to build an 800+rwhp car), and for street ur mums camry would flog the shit out of u, have no boost till 6k lol... i have seen a guy get custom manifolds made up for smaller gt2870's or something rather to mount them high, (HPI magazine) although it looked funny as they arent that big in terms of size...
id personally go twin 2530's low mount save money on manifolds and have a crazy response set up
https://www.sau.com.au/forums/topic/185101-500hp-atw-rb26/#findComment-3360139
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
