hey im looking at buying some coby extractors?
good on ya.
who has them and are they any good?
i do, and yes they are good.
did power/responsiveness inprove?
outright power, no.
response, yes.
you can get them shipped from new zealand, or pick one up second hand.
all other questions can be found by searching through the NA thread, there's been alot of discussions (pros/cons) about it. far too long to discuss, it's all there though.
yeah they don't advertise it for whatever reason.
i'm not too sure on prices to be honest, as i organized the group buy ages back. it was a significant saving though, we looked at ~$100 OFF each header.
quote from my group buy thread. should be much cheaper now with the stronger aussie dollar.
They retail for about AUD$260.
shipment options
International Express, 1-3 days (AUD$100.00)
International Air, 3-6 days (AUD$70.00)
International Economy, 10-15 days (AUD$60.00)
hpc coating
one set of headers (AUD$170)
1-3 buyers
D12 rb20/25de headers (AUD$220)
D5 rb30e headers (AUD$220)
F124 gasket (AUD$15)
4+ buyers
D12 Headers (AUD$180)
D5 rb30e headers (AUD$180)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
