Vn 3.8 Stroked To A 4.0 Engine In My 32r
  • Replies 50
no hes got a point guys.....i shifted the daewoo matiz engine into my r33 gtst.....fully sik bro.....unfortunately the swap of the rb25 into the matiz ended in tragedy......massive torque steer to the front wheels .... ended up cleaning up the clown who was trying to promote some sale on the side of the pavement......then swiped a couple of rare parrots that were flying in from africa for a visit.......and then i thought i had control...but it wasnt to be.....i was barrelling down on a granny.....she held up her cane for self defence......and i think that saved her life cos the cane came flying through the matiz window and through the back and hit the joker in the car behind.....
his car went towards the side slammed into a pole...and catapulted him so high that the police are still waiting for him to return to earth.......last i heard he hit the ISS and the russian cosmonauts were singing "volga boatmen" - now we are waiting for nasa to determine if the joker damaged the heat shield or not........
back on earth....the cane was still flying at tremendous speed - it knocked over a couple of hookers that were hooking next to the clown.......fishnet stockings everywhere, clowns nose rolling down the pavement......a kid on a skateboard hit the nose and flew into the garbage truck that was trying to drift around the mess.......
it was terrible......
dont put the rb into the vn man....then thats what will happen to u.......
hey that reminds me of the new ignition dvd it has an red r34 in it with the ls1 v8 and a twin turbo setup that has 400kw at the wheels and revs up to 7000rpm all the internals are stock and can handle a bit more power. he uses it for drifting and said its getting boring and wants more power so a company has built a bigger v8 and he is putting on better turbos so he will even have more power, now thats crazy.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
