Vn 3.8 Stroked To A 4.0 Engine In My 32r
  • Replies 50
no hes got a point guys.....i shifted the daewoo matiz engine into my r33 gtst.....fully sik bro.....unfortunately the swap of the rb25 into the matiz ended in tragedy......massive torque steer to the front wheels .... ended up cleaning up the clown who was trying to promote some sale on the side of the pavement......then swiped a couple of rare parrots that were flying in from africa for a visit.......and then i thought i had control...but it wasnt to be.....i was barrelling down on a granny.....she held up her cane for self defence......and i think that saved her life cos the cane came flying through the matiz window and through the back and hit the joker in the car behind.....
his car went towards the side slammed into a pole...and catapulted him so high that the police are still waiting for him to return to earth.......last i heard he hit the ISS and the russian cosmonauts were singing "volga boatmen" - now we are waiting for nasa to determine if the joker damaged the heat shield or not........
back on earth....the cane was still flying at tremendous speed - it knocked over a couple of hookers that were hooking next to the clown.......fishnet stockings everywhere, clowns nose rolling down the pavement......a kid on a skateboard hit the nose and flew into the garbage truck that was trying to drift around the mess.......
it was terrible......
dont put the rb into the vn man....then thats what will happen to u.......
hey that reminds me of the new ignition dvd it has an red r34 in it with the ls1 v8 and a twin turbo setup that has 400kw at the wheels and revs up to 7000rpm all the internals are stock and can handle a bit more power. he uses it for drifting and said its getting boring and wants more power so a company has built a bigger v8 and he is putting on better turbos so he will even have more power, now thats crazy.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
