So who's playing bioshock and what are your thoughts?
I just started playing on friday and im pretty impressed.
It's the first game in a while that I have been able to sit down and start to play and not realise a few hours have gone pass...
So far the story and all is pretty interesting and freaky :unsure:
What path have you gone down so far? save the little sisters or kill 'em ?
this time I have chosen to kill them, I will go back again and do it the other way after i finish it i think.
https://www.sau.com.au/forums/topic/185203-bioshock/
d/l from steam or copy? i dont think theres a working crack for it yet
farked if I know... its a full distro of it from LOLCAT. they had a previous release which was nuked cos it didn't work, apparently this ISO works. Its been trickling thru at 5kbps for the last week... irc fservs :)
https://www.sau.com.au/forums/topic/185203-bioshock/#findComment-3352955
I know of a downloaded copy thats been working for 4-6 weeks now.
I havent played it, but seen it a few times, looks interesting.
it was available 2 weeks before its australian release.
my cousin said it lasted a whole 7 hours before he completed it... and that was taking his time.
sounds like a waste of time to me... is it even playable online or anything?
https://www.sau.com.au/forums/topic/185203-bioshock/#findComment-3356300
Yeah 7 hours is i think a bit mystical.
I think it was out more than 2 weeks? Cant remember... the xbox here was having 'dramas' so bioshock only started 'working' last week.
That said the game has been finished and i think that was in about 4-5 days of reasonable playing (so maybe 4 hours/day)
https://www.sau.com.au/forums/topic/185203-bioshock/#findComment-3358569
Yeah I finished it after about a week.. not playing every day.. the story line is great! Was abit disappointed in regards to the enemy's. After about the second level you are introduced to every enemy in the game, so it doesn't get much harder after that.
I was told that it is more rewarding to save the little sisters. I haven't played again and gone down the path of harvesting them though. Make sure you explore every single room on every level, or you will miss out on allot of the game.
https://www.sau.com.au/forums/topic/185203-bioshock/#findComment-3358777
I bought the PC and 360 version. And i prefer it on 360.
Fantastic game though, still haven't bothered to finish it yet but am getting there.
I loved system shock and it's by the same guys so i think it's awesome.
https://www.sau.com.au/forums/topic/185203-bioshock/#findComment-3360462
7 hours? thats a load of shit..
7 hours doesnt even get you half way, and its not like i've never picked up a game like this before..
Yeah thats probably about right. I completed it on the hardest level in about 10 hours. And that was taking my time collecting all the radio's and searching for money etc
https://www.sau.com.au/forums/topic/185203-bioshock/#findComment-3364610
I got a cut down version running on my PC, the download was about 4.3GB I think. Tis pretty good but it seems a little hard when you only have a revolver and wrench, I got killed about 7 times by 5 zombie things before killing them all....
https://www.sau.com.au/forums/topic/185203-bioshock/#findComment-3372190
I am running a S939 AMD 3700+ @ 2.5Ghz, 7800GTX OC and 2GB of DDR1, its slightly jumpy when the games requires a little more processing power than I have but 96.1337% of the time its seemless at pretty high settings.
haha that sounds farked.. full version ftw.
Well, we'll see I guess. It was actually a 3.41GB .rar file with the game already extracted plus a registry update inside. Once extracted and now that I've played for a bit its 5.57GB
https://www.sau.com.au/forums/topic/185203-bioshock/#findComment-3385876
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
