Very sexy, you need to get it lower though. And take some pics on flat ground :O
Yeah........ it would look trick if it was an inch lower or 2....I don' want have drama's fitinn the 255's in though........
Id say that'd be the next mod.
If I lowered it, I would have to lower it 10mm per week(gradually over 4 weeks)that way my wife wouldn't notice straight away.................... :laughing-smiley-014:
I live up in the hills and don't have any level area's to take any pics...........I'll find some flat ground and take another few pic's.
It doesn't look to high on level ground, but it could go down a smidge. :D
https://www.sau.com.au/forums/topic/185271-new-ssr-rims/#findComment-3360767
How much? and give it to me!
Do they come in black?
Sorry for the hijack but.....
Which would y'all get out of these SSR's (if they do black) 17x9
or
URAS NS-01's in black, 17x9.5 - http://www.skylinesaustralia.com/forums/in...howtopic=167381
or
5Zigen Pro Racer GN + in black or bronze, 17x9.5 - http://www.nengun.com/5zigen/pro-racer-gn
???? Decisions ????
https://www.sau.com.au/forums/topic/185271-new-ssr-rims/#findComment-3363241
or
or
???? Decisions ????
1600 fish for the rims, 14 fish for the skins
Bronze and Grey(no black) in stock at C_RED from Jash check out their website under SSR...........grey looks good but too much grey on grey GTR..
The bronze GN's from 5Zigen look Schweeeeeet.........too. :wave:
Edited by windbag
https://www.sau.com.au/forums/topic/185271-new-ssr-rims/#findComment-3363678
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
