  • Replies 200
ok gals and guys ,
I have decided to start my own business so im looking to move the gtr to fund my business further as i will purchase another later on down the track i must sell my pride and joy . taking serious offers now i will consider all good ones may trade for some thing of lesser value with cash on top .
regards
Anthony
hi all
well im thinking of selling the gtr its some thing thats been on my mind for a while and now i thought id put up an expression of interest and see what happens .
i am in no rush to sell the car and if i don't get the right price i will just leave it in the garage seeing thats where it spends most of its life this has been an extensive build with no corners cut whats so ever and all parts have been purchased new from a very well know performance company in Sydney
mods are as follows
body:
full custom respray in red
standard gtr kit
bodyform 1 piece side skirts
original n1 nose vents
d speed clear side blinkers
hid kit
interior:
standard interior in a1 condition
4 defi gauges in white boost,exhaust temp,oil press,oil temp
defi link controller
greedy type s boost controller
greedy gear knob
mines 360 speedo
top of the range mongoose alarm
custom pioneer stereo system
tourqe split controller
power fc and hand controller
fire extinguisher
wheels & brakes&suspension:
19 inch rays g-games 99b's only set in the country for a gtr in this size
hankook tires 19-265-35
f50 brakes up front brembo caliper 350mm rotor
rear cross dimpled and slotted rotors brembo calipers same color as car
braided lines
project mu pads hc series all round
tein flex coil overs all round brand new
front toe kit
front and rear strut bars
cusco brake cylinder stopper
nismo gearbox mount
engine
bottom end:
strengthened block
new r33 crank
eagle rods
cp pistons
acl race bearings
jun pump
trust extender sump
all blue printed and balanced
os twin plate clutch
full tomie gasket kit
full hks hiper exhaust
gates timing belt
new tensioner and idler bearing
oil cooler and relocator
nismo engine mounts
head
extensive porting
full reconditioned every thing new
hks stage 2 cams
hks cam gears
performance springs
retainers
buckets
seats
tomie head gasket
tomie intake gaskets
tomie exhaust gaskets
tomie oil restrictor
arp head studs
twin garret 2871r turbos 400hp each
greedy intake kit
twin z32 afm
apex i filters
greedy radiator
gates hoses
hks fuel rail
sard 700cc injectors
speed flow fittings and braided hose through out
hks fuel reg
hks 280l pm pump with custom relay kit
arc water breather kit
custom inter cooler piping
custom plazmaman inter cooler only one on a gtr
oil cooler kit
custom catch can
relocated battery
full engine bay detailing
hks dump pipes
hks actuators
carbon covers
split fire coil packs
billet fuel filter
greddy radiator
fuel pressure gauge
race power steering cooler
welllll there is alot more stuff i just cant think of right now but pics speak for them selves so if your iinterested the price is
$41500im sticking with that price but open to serious offers or trades of same value
no joy riders or tyre kickers this is only open for SERIOUS BUYERS ONLY who know the value of building a car like this and know wat they are looking for and what they want !!!
all enquirers email me at [email protected]
thanks all
anthony
edit: i have now also fitted a:
greddy type r plumb back bov
greddy air diffuser
new cam angle sensor
and a race buddy club exhaust no mufflers no cat just pure porn sound :)
NEW PRICE DROP 36K
36K people going cheappppppp people grab a bargain my loss is your gain need more funds for my business !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
open to offers near the value asking considering that i have dropped a large amount ..
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
