Well story goes the other night i took my car out for a drive and got a knock reading of 207 on my S-AFCII.
The controller is installed correctly and knock was set correctly and previously the highest reading i had gotten was 26.
At cold start up i get a very small reading as with cold idle. Once the car is fully up to temp i.e after a 3 hour trip and stopping at traffic lights i get a reading in the mid teens.
The reading of 26 occurred when i heel n toed from 5th to 4th to 3rd.
But the reading of 207 happened on a very cold night <10 degrees. I was at 2000rpm and having just previously installed a 3"dump/front pipe and 3" high flow cat i wanted to see how it would pull. Went to 90% throttle and revved it out to 4300rpm before shifting and thats when the reading occurred. Prior to this i hadn't gone past 50% throttle.
To double check i put it into second and did the same thing and got a reading of only 4. I haven't had the car tuned yet since i installed the A/F controller (booked in this Tuesday) but just wanted to hear your thoughts as to why i i got such a high reading.
Car: HCR32
Mods: 3" turbo back exhaust with 3" high flow cat, Greddy VSP-L FMIC, M's Filter with CAI, Walbero Fuel Pump. Everything else is stock.
The car does however run very rich. There's unburnt fuel over my rear bar and inside of the exhaust is i thick lining of carbon build up/soot. I always run it on Bp Ultimate. Apexi TT o2 voltage is constantly in the high .90's and theoretical A/F ratios is usually in the 10's. Is it just that the car is running super rich, or that it was a really cold night?
https://www.sau.com.au/forums/topic/185303-knock-reading-of-207/
Shouldnt your motor be dead with a reading like that?
Maybe you went over a bump at that moment and the knock sensor picked it up?
Or a rock flicked up and hit the engine
I don't know. I know its extremely high and that the ecu reads genuine knock at 120 so who knows how much damage was done at 207? The road was flat but rather bumpy so that could have been the cause, a freak reading perhaps, don't know about a stone but quite possible. I guess i'll find out more when i go to the tuners on Tuesday. But for what its worth car has been running fine since...
It'll just be a cell that needs adjusting. As you said it was a horridly cold night.
Thats the cause.
No real need to worry. Whilst 207 isnt great, a once off shouldnt post any problems.
If you stayed up it and it knocked 207 on and off for a few mins i'd be worried.
Thanks R31Nismoid that puts my mind to rest a great deal.
I'll be able to sleep easy tonight...figuratively speaking...as I'm on my 3rd No-Doz tablet as i have an assignment for uni due this morning...
Anyway I'll let you know how i go with the tune. Thanks guys.
Are you sure?
Mine used to run so rich that I had ignition break down (well in to the 9's); with a cat it never used to spray soot over the rear bar. The cat in that tune/lack of tune only lasted a couple of months before breaking in to bits and blocking. It wasn't noticeble it was stuffed until we checked the cat out next tune. And it was nackered. :yucky:
So if its running as rich as you say; you cat will be near stuffed.
If its running as rich as you say sort it out ASAP as the new cat won't last too long.
OR.. wind the boost up a little :yucky:
With stock ecu's and a little boost they don't run 'that' rich. If your still getting soot over the rear bar something is up with the car.
I had one of these years ago and i never found the knock reading to be consistant.
Mine would start low and gradually increase as the car got hotter, and so did the unit with all the lights running thru it.
Cruising down the freeway it would gradually climb to 100 with no change in driving style.
And don't compare it to knock reading on a Power FC either
Once i went to Power FC, even before it was tuned (base map), i drove 1.5 hrs to the Hitman for a tune, same freeway conditions etc, no knock over 15.
Maybe my SACF was FUBAR ?? Who knows.
Yeah thanks, the car is booked in for a tune tomorrow at Geelong Tune-Up Specialists. Hopefully they can sort everything out.
As anyone else had there car tuned there?
Hopefully after only a week of driving it as is the new cat will be fine.
I'll post up a dyno sheet and what not when i get back from the tuners tomorrow.
I have seen them that high, but looking at the long, 99.9% of the time, the spike occurs on VCT change over, so what you hear is the change over of the VCT or somethign associated with it.
As long as you don't drive it at such a high knock reading and it was a one off, it was propably a glitch.
Who's comparing it to a Power FC?
Well the highest reading that i had gotten previously was only 26 and that was when i heel n toed twice in quick succession.
Other than that highway and city driving the highest reading was in the mid teens. So i would say that it's pretty accurate.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
