Hey guys, just got hold of an intercooler off an F6 Typhoon.... Would this be a suitable upgrade for an RB25DET? Was keen on this because it's got the piping returning to the same side as the inlet, so I was hoping to use much of the factory piping. Anyone know the dimensions etc of these coolers (It's in the post so I can't measure it).
Thanks, Tim.
https://www.sau.com.au/forums/topic/185344-ford-fpv-intercooler/
You probably should have checked out the dimensions and whether it would be a decent upgrade *before* you bought it... :yucky:
Id assume itd be better than the stock RB25 cooler though, not sure how much of the stock piping youll be able to use though, Im sure youll need at least some custom piping made up to reach it.
Yeah prob should have, but it only cost me a bit over $100.... Some piping will have to be made up, I just didn't want to go cutting any holes in the engine bay. Here's a pic of it anyway.
The xr6tubo/typhoon coolers are pretty good flowing coolers.
Most of the XR6turbos run minimum 248rwkw on stock intercooler with no issues, so I don't see why it would not work for your applications.
Only issue now is custom piping.
Rotate and mount the cooler this way if your facing the front of the car. (picture attached)
Basically you could set the piping up like a return flow setup.
Leave the piping stock in the engine bay as it runs in to the guard, take the stock cooler out and making the piping from the cooler join onto the exiting piping from there.
Hope that makes sense.
Edited by abu
but then the pipes are angling forwards not back towards the engine?
It could work though.
not if you just spin in 180 degrees, not actually turn it over.
Just look at the picture I attached a few posts up.
Edited by abu
it would still be less work (and money) then fitting a hybrid style cooler, and less money than a cooler kit that uses the stock piping.
i don't think it perform that differently to some of the apexi coolers that i have seen on 33's.
$100 = bargain.
considering an R34 SMIC usually goes for about $150
cusotm piping might wet you back $50 - $100 max.
this setup would easily cool what the stock turbo could push out and probably in to the 250rwkw type figures.
Edited by GTST
Will let you all know how it goes.... even if it costs $200 to get it all set up and fitted, as Mad082 said, will still be cheaper than any front mount kit I've seen, and I shouldn't have to cut any metal.
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
