Ok so i want to change my parkers in to my indicators and use the parker wirers to have angel eyes. i have looked on the forums and i know its just changing the wires around. the problem is im not too confident on what im doin and would like some assistance! will to pay a carton of beer to who ever wants to help me out!
or if some can show me where a really detailed DIY is!
im not sure what bulbs i would need for the indicators so if anyone knows or can point me in the right direction that would be great too.
thanx
https://www.sau.com.au/forums/topic/185833-a-lighting-issue/
For the Indicators, go with the LED ones, and at Auto1 or Repco it should come with a slot to fit it in with wires hanging out so you can cut old wires from old one and connect to the new one,
For the angel eyes, cut old park light wire, and connect to the angel lights wire, this was done to my brothers car and works a mint.
Can give you a hand this weekend if you want, but just gotta find myself a car first to get around with..haha
Edited by viet_boi
Yep like this!!
Cheers for the offers deffinately take you up on it ill let you know if im free this weekend! i dont have the angel eyes yet tho so maybe in a week or so when i can buy them!!
not sure if i should go with the blue angel eyes or the white what do you all think??
and ill post pics once complete!
cheers
i guessing your tring to make it look something like this?
i think blue would get alotta police attention
Yep it sure does.
I used to have blue LEDs over my number plate which made it imposible to see it, just looked like there wasnt even a plate there. Cops didnt like it one bit. Nothing happened to me for that but he gave me a lecture bout it and he fined me for something else. . . . . w**ker
yeah those 2k ones look sick but way outta my price range!! so ill probably get white ones, but i cant find thick ones (if that makes sence) like the with of them is about 1mm! ive seached ebay but can only find the thin ones!!! any ideas?? also what size the ones ive seen come in 5cm, 6cm, 7cm then jumps to 10 12 and 14 cm. so i was thinking 7 or 10 altho the 10 might be too big, but then 7cm looks a bit small! DAMNIT
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
