hey all i went to get a shift kit fitted in my r33, and i found out that i have a 5 speed auto and that there is no shift kit for this.
just wondering has anyone got any info at all about these? and also is there anyway to beef them up?
thanks heaps in advance.
https://www.sau.com.au/forums/topic/185906-5-speed-auto/
oh you mean the 4-speed auto
standard is 4-speed with OD - whoops i mean't 4 speed in this :) changed it now
not sure why the shift kit won't fit in it though? as they are the same model number? and have mostly the same parts?
what number is on the box itself?
Edited by skybarge
https://www.sau.com.au/forums/topic/185906-5-speed-auto/#findComment-3364032
wierd, R4's are the 4speed, that's that the 4 stands for
Jatco RE4R01A which is standard in most skylines, are you sure you haven't got that?
Which shop are you talking about?
Might be good to talk to MV Automatics or Knox Automatics, they'd know what fits your box.
I think they use a manual valve body upgrade from a Nissan Patrol in their kits with some welsh plugs to block off some of the holes
If you have the 5-speed it's be:
Jatco JR507E transmission
which is what come in Cimas, Presidents and a few other V8s and things and possibly some skylines, if you've got the 5 on your box number, then maybe someone put int a v8 box, changed the bellhousing, tailshaft and a few other things to get a longer drive ratio, it's a tad strange though
https://www.sau.com.au/forums/topic/185906-5-speed-auto/#findComment-3364596
RE4R01A - 4 Speed
RE5R01A (or JR502E) - 5 Speed
Either way I know MV Automatics' have done shift kits for 5-speeds (eg. Zoom/ HPI's project 11sec 4-door) so, Im sure other competent trans specialists are able to do it.
https://www.sau.com.au/forums/topic/185906-5-speed-auto/#findComment-3364640
There was a 5 speed fitted to some skyline models - check out some past issues of Zoom mag in their R33 4 door project car. They did some upgrades to the box as well if I remember rightly.
https://www.sau.com.au/forums/topic/185906-5-speed-auto/#findComment-3364669
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
