just wondering will the R34 GTT steering wheel will be able to be used on a R33? and also the mats will they be suitable for a R33?
Cheers
Chi
Steering wheel should fit a 33 but ask in the forum , someone would have done it . mats are on hold for someone else.
* R34 GTR wheels +Toyo T1R's 275x35x18 , The wheels are in excellent condition, no gutter marks and very clean , tyres have under 5000 km with about 7mm tread left , theese tyres are top of the line Toyos , they retail over $500 each. $2950 for the set of 4 wheels and tyres.
* R34 GTR GTR rims ( just rims , no tyres ) Again excellent condition , no gutter marks and very clean, you will not find better rims .. $2290
* R34 GTR wheel centre caps , replace your lost/broken caps , excellent condition $65 each or $195 for the set of 4.
* R34 GTT steering wheel with airbag, excellent condition $390.
* RB26 N1 actuators, ajustable like HKS, excellent working order $175 for the pair.
* RB 26 Stock exhaust manifolds ( R33 GTR) $90 for the pair .
* RB 26 Stock Dump pipes ( R33 GTR) $60 for the pair [/s] SOLD
* RB 26 exhaust heatshields , make an offer.
* R34 GTR floor mats , complete set of 5 , excellent condition $275 for the set. on hold
*R33 GTR series III clear front B/Bar blinkers , genuine Nissan items including the grills $240. SOLD
* R33 GTR Jun rear pods white $75 for the pair. SOLD
* R33 GTST headlights, very clean lens, no fogging, drivers side perfect, passengers side slight crack has been repaired $275 for the pair SOLD
* R33 GTR Nismo cluster white face looks in great condition , she came off a half cut , I can't test to see if its working , but you are welcome to try it before buying $ 420 SOLD
* R33 GTST cluster, looks good, nothing broken , unknown if it works or not $40 for parts SOLD.
* 3 Gauge pod to suit R33 , sits on the top of the dash to suit 60mm gauges $70
I will add stuff as I find It . I'm in Sydney and I will post at buyers expense, more pics available on request for buyers .
* Genuine R34 GTR gear knob excellent condition $140
* R33 GTR turbo coolant and oil lines $80
* R34 GTR complete stock clutch and flywheel $190
* R34 GTR 3" Fujitsubo Legalis R Catback, Just like new $690
Updated
Edited by wrxhoon
* R34 GTR floor mats , complete set of 5 , excellent condition $275 for the set. on hold SOLD
* 3 Gauge pod to suit R33 , sits on the top of the dash to suit 60mm gauges $70 SOLD
* Genuine R34 GTR gear knob excellent condition $140 SOLD
Updated , will consider offers on some items .
* R34 GTR wheels +Toyo T1R's 275x35x18 , The wheels are in excellent condition, no gutter marks and very clean , tyres have under 5000 km with about 7mm tread left , theese tyres are top of the line Toyos , they retail over $500 each. $2950 for the set of 4 wheels and tyres. SOLD
* R34 GTR rear floor mats ( only the 3 rear mats , no front mats ) $140
hey can someone tell me if the 34 steering wheel will fit on a 33gtr, and will the airbag work? 33 steering wheels are uglyyyyyyyyyyyyyyyyy need to change it.
thanks
It will bolt on but you may have to mod the electrical plug ( not sure ) the airbag will work with your ecu.
* R34 passengers side airbag , perfect condition includes the cover , sold
* R 34 Airbag computer , the one that goes under the centre console and must be replaced if any airbags are deployed ... make an offer
Updated .
Edited by wrxhoon
Will the actuators fit onto an RB25 turbo? How much boost are they running? and willing to separate them?
No they will not unless you mod them, You can set the spring well over 1 bar , no I will not separate .
  • 3 weeks later...
* R33 GTR turbo coolant and oil lines $80 SOLD
* R34 GTR complete stock clutch and flywheel $190 SOLD
* R34 passengers side airbag , perfect condition includes the cover [/s] SOLD
Updated , some stuff still left, may consider offers...
  • 2 years later...
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
