  • Replies 409
Posted Images
Ok want to have a meeting....
Guys please tell me what the best day/night time????
and want it to be central again for everyone so we all travel :P
Please suggest away wnat to have meeting in about 2 weeks!!!!!!!
date??
time??
desination??
West Ryde hotel
Saturday
2pm
does this sound ok???
Sounds good to me :)
We need money, and forms if you haven't given them in yet... and a small discussion on what theme we are doing would be nice, otherwise it's going to be my choice, and you won't like it :P
I wont be able to make a meeting in Sydney as Im in Canberra and I dont really have the cash to blow on fuel for the round trip, can someone take notes and advise us interstate members of whats happening?
Also, I can transfer the cash for entry via net bank if someone has details...
I'll get Jess to PM you about the Bank details...
If anything comes from this meeting, unlike the last one, then I'll keep you informed... I hope to have a theme decided on by the end of this meeting, otherwise I'll just pick one myself...
We have set up lights, truss, plasma, controls, some other shit that i don't know what they are... all for the show :ermm: at the moment, the Toxic waste theme may be going ahead... That is what I will choose if a group decision isn't made...
But we can also just use the lights and shit to make the cars stand out... lots of choices :dry:
Meeting next saturday !!!!!
Date: 10th Nov Saturday
Destination: West Ryde Hotel
1021 Victoria Rd
West Ryde
http://www.westrydehotel.com.au/
Time: 6pm
Please attend as will be going through theme and make sure all forms are filled out....
Thanks
Jess
drd-00f can you pm me any details that i need to know and wat i need to arrange.... let me know if my car is still cool to show
oh and one other thing is it true that interstate cars get free entry???
Edited by redevil
Ummm waddya mean? Basically you need to fill out the form and fax it back to me, and send money... I spose you will also need to book a room somewhere...
Try the Novotel hotel, It's about a 3 minute walk from the show, and you can hold parties of a night :)
Interstate Competitors recieve one (1) free car space. Additional spaces can be purchased at regular prices
So basically, having interstate competitors, gives us spare room, but it's not free... unless you have a friend you want to bring? What I will probably end up doing is using that 'free' space, and use an entry amount to cover other costs such as power, hire of other stuff etc... I was going to add $20 each to the entry cost to cover that stuff, but it seems like this is a better idea :D
The idea behind the free space is to get more involvement from other states... at the moment we will have 2 'free' spaces, which will cover cost of power... and some of the hire fee...
I need to get all the forms together to figure out what it will cost us all up... But it should be $120 for everyone who isn't me basically :ninja: Once I have the forms together, I'll get on the phone to AS and sort it all out :P
When you do the form, just leave the Payment Information area blank...
Due to the lack of helpers, and inability to most likely get the props needed to make a theme look good, we are not having a theme...
We do still have several thousand dollars worth of equipment coming though, and we can pick colours, movements, and other stuff when we are there...
But due to the small amount of help I have recieved, this is all I could pull off... Perhaps next year we can do a decent theme and what not, but for now, we will have to settle with thousands of dollars worth of lighting, truss, plasma screen and effects... :D
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
