  • Replies 409
Posted Images
i know no one cares, but sadly my silvia will not be there:
a) i have to work now
b) paint is still shagged
c) just spent alot of my money on repairing my manifold.
once i win the lotto and fix everything that needs fixing i'll be there
Well, Im probably not as stretched as then DrDoof, but fuel for the trip there and back is an easy $140.00... :)
This is why bikes are better. It costs me $13 to fill up with 98
Oh of course... SAU needs that money for... umm...
Hiring goons to kick your butt!!
Next time, a bit of warning would be nice, we waited and waited just for you, and nearly lost all 12 spots...
Also, communication is key, check your PMs to make sure they aren't full or anything... You are annoying to get a hold of to say the least...
when is the earliest possible time that we can leave our cars @ homebush on friday? and also, do we leave our keys with the organiser or we dislpay our cars @ our spot and take the key? hows is it going to be done? i don't have much info other than that the show's happening on saturday and sunday
Can anyone tell me if its worth trying to get a train from the arena to Parramatta at 10pm?
Or can someone give me and my missus a lift?
Pretty please... :)
Im staying in Parra on Friday night, but I'll be at the Ibis Homebush after that...
You can leave your keys with us if you like :)
There is a slight problem with going on the dyno, especially if you won't be there, and we won't have keys...
I'm going to be there all day, every day... it's really up to you though, you can take the keys if you like, and come back around the time you are due on the dyno...
I will be at homebush by about 2pm I hope, they don't start moving people in til 3, but we have a lot of setting up to do before we can do that... So if you are fine with it, you can park your car in there at 3, and we can move it in when we're ready :wave:
I will be there on sunday as a spectator. See you all there! Cant wait!
Coolies, come say hi :)
Pretty please... :)
Train isn't that bad, I thin there's one that goes straight to parra from homebush, so you should be all good...
Dunno about a lift though, I'm local compared to Parramatta :)
yeah dude, i've been away mate was suppose to keep you guys updated with everything but clearly hasn't done that... I fully apologise for the inconvience ey... i'll be down there friday morning... not familiar with area were abouts can i meet you guys or just at 2 at homebush
Hey guys, from what I've gathered I'll be driving Brentons (redevil) car down. A few of my mates are showing their cars aswell, so if their set up time is earlier than yours we'll just meet you at the show grounds. To make it easier I'll give you guys my phone number aswell so that if you can't get hold of Brenton, you can ring me. Anyway, number is 0412 177 050. We're staying in Ryde but hoping to have a car organised to get to and from the show.
Thanks,
Andrew
Edited by option1
We will be there around 7ish with Laurens car aswell :nyaanyaa:
Yep basically you take your keys with you unless you are happy for someone to drive your car to dyno stand or db stand...
There is usually a massive line up from 2pm onwards so when ever you get there guy's is cool, We are still not totally decided on how the cars will be display, Jay and the flooring basically need to get in first to set up and then go by who rocks up..will need extra hands to help set up and get stuff sorted out :nyaanyaa:
So we have:
1 X R34 GTR
1 X R34 Gtt
6 X R33 GTS-t
2 X R32 GTR
Is this right???
well...here's my effort....
had last friday off to drop car at Bodyform to get sideskirts changed...around 400klm round trip
worked today...left home straight after work to pick car up from Bodyform and drop off at Jet detailing at Brookvale...another 500klm
run around thursday picking up display board and stickers...about 150klm
pick car up from Jet detailing friday morning, drop car at croydon's, pick up from croydon's, set up at autosalon and head home...another 500klm
leave home saturday morning to attend show, stay saturday night, attend show all day sunday, pack up display and head home...about 400klm
phew....almost 2000klm...for a bloody car show...
this is the final Sydney Autosalon i do...if we crack 500AWKW in front of a good crowd it will be worth it.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
