Wierd request I know, but I need to borrow a GTR badge so I can take some measurements off it, and cast it. Would prefer an R33/34 (think they're the same shape) but will settle for an R32.
Anyone got one lying around that I can borrow for a week?
I just finished silicone casting some model pieces, and have a little silicone left over, so I was gonna give making the GTS and GTt badges a go. If I can get a cast of the GTR badge and some measurements, then I can mock up a clay GTS badge and hopefully cast it to make some acrylic badges.
https://www.sau.com.au/forums/topic/186521-wanted-to-borrow-gtr-badge/
Theyre not the same between R32/33/34
cheers bec n sarah.
yeah sunshine steve, ideally I guess I'd wanna use the R34 one coz its the latest design, but I'm not really picky. I know the R32 one and the R34 one are totally different, but I assumed the R33 and R34 were similar.
R32
R33
R34
Don't really see much diff between the R33 and R34 other than the fact that the R33 GTR badge has a deeper bevel. Wouldn't wanna cast the R32 one as you'd have to colourmatch a part of it to the car it goes on.
ceedub... R32's a little too different to the others, hopefully can get an R34 one, but failing that R33.
so bec and sarah... i can haz GTR bdjus?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
