Hi all..
I have the choice of getting a Microtech for my R33 or going to Dr Drift so they can tinker with my ECU and still get some big power out of it.
Microtech is about $1400-$1500 from one of our suppliers here and to get my ECU done, Dr Drift quoted me about $1300...
I thought Dr Drift were cheaper then that and now I don't know what to do!!
What are your thoughts people??
https://www.sau.com.au/forums/topic/186704-microtech-ecu-or-dr-drift/
R33's are more expensive from Sam as there is more work involved.
I've got a couple of mate's going to Sam to get their cars done very soon.
Personally I'm not a fan of Microtech's, and my car is tuned by Sam, so you know what I'd recommend!
take into account that you will still need to pay to get the micro tech fitted aswell as dyno time to tune it
Yeah, it's looking like Dr Drift for me... that was what I was leaning towards anyway. They sound like they know what they are doing....
can I ask why you're not going with something simple like a power FC?
only thing about a flashed ECU is that its a once off, and to redo it you'll have to reflash the thing, and there's only so many people who have the knowledge to do it. At least with a power FC you have a choice of tuners.
that said, given the choice between microtech and sam, I'd go with sammety sam.
PowerFC too hard to find now.... Anyone selling??
depends on how much power you are after, tweaking the comp will only get you so much power output, can you run larger injectors off a tweaked comp? or do you have to run a aftermarket ECU? i have a microtech ECU with 550cc injectors ect., you can get them cheaper than that second hand...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
