I haven't heard yet, but have been too busy to ask.
I've annoyed Ben a fair bit lately asking about various changes, so one more "are we there yet" and it will probably come back in pieces, or worse making 140 KW.
Fingers crossed, accomm booked and leave pass organised.... :D
"Hi Ben, it's BBGTR here, is my car ready yet is my car ready yet?"
"140kw at the wheels you say? uhh ok"
thats fine with me! then you'll never catch me!!!! :(
  • Replies 96
I've just realised I need a new fire extinguisher after Winton's effort!! :D
Well it's all coming together.....
Hi all
Just a quick note to let you know that I have received and accepted your entries for the Piarc October Sprint,
Thank you for entering and I will see you on the Saturday and Sunday morning.
Gates open at 7am on Saturday and 8am on Sunday.
Regards
Theresa Ford
Sprint Secretary
Phillip Island Auto Racing Club
Everyone is dropping like flies! Aarons not making it, no idea if Jack is, Ben's obviously out as well. Haven't heard how Jesus is going either so I might yet have to wave the Vic skyline flag.
I WILL be there, brand new turbo sitting on Ben's desk ready to go in..... :D
Yep - I sent a bank cheque too... As did Fooey... Neither of us got a response.
Maybe they just took our cash and ran!?!?
No email either.
I sent a bank cheque so i wouldn't know if that went through either.
Andrew, was there a contact number on the confirmation email you received?
No email either.
Good to see you'll be down there Archie. As Snowy said, no ph. number unfortunately.
Wind the boost into that big single mate, and I'll sit behind for a tow!
Regards
Andrew
Thanks Bec
I emailed Theresa so I'll wait to see if i hear from her.
Andrew
LOL hardly. I saw your car last weekend and I know she's sorted now so if anyones going to be sitting behind it'll be me >_<
Still, I would love to follow you around to see the differences between our cars.
Well my car is on the back-burner cause of PI this weekend and the need to get a number of cars ready :sorcerer:
Not like i need it in a hurry anyhow lol.
So there should at least be a few going >_<
Yeah I got the same email yesterday, and I stated on the form that I'll pay cash on the day...
My car is finished and ready to go!!!!
Now with (a little) more power....
Can't wait to do another full track day...(fingers crossed)
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
