hey guys
just finished the following mods: 440cc inj, tomei fuel pump + fuel regulator, greddy emanage ultimate, prfect b. already have a cooler, pod, turbs back 3"exhaust. Am producing around 175kw. Looking at gettin more power without increasing the actual size of the turbo what would i go with next for more power? am open to high flowing but thats about it in the way of the turbo as i dont want it to stand out if being defected!
any ideas would be helpful and is this the amount of power youd expect with these mods?
cheers guys.
https://www.sau.com.au/forums/topic/187102-new-mods-completedwhat-next/
That is massive amounts of power out of a hyundai getz. :(
maybe you should update your cars section of you profile so that we know what you own and can better advise!!! :no:
lol...I have a getz aswell...dont bad the hyundai's...unless its an EXCEL!! :rofl:
Ryan
Not too sure what car you have, but i recently pulled 171kw at boostworx without larger injectors or a different ecu, would think you'd pull more than 4 extra kw with those mods but i could be wrong
On the cheap side, you can get a RB25 turbo, which is just slightly bigger than the 20 and it will look just like stock, remap the ECU and youll be around 190rwkw (at least I was)
Sell the emanage, to cover some of the costs, and enjoy!
he has to be talking about an RB20 dude, why bother upgrading injectors and pump and regulator to get only 170kw. It has to be an old lazy RB20 :)
he has to be talking about an RB20 dude, why bother upgrading injectors and pump and regulator to get only 170kw. It has to be an old lazy RB20 :ninja:
i don't think the rb20 standard turbo can even handle 175 kw and last for more than a week. upgrading injectors and pump wont produce much more power unless you have the air flow to make it, like a bigger turbo. you'd be able to get a little bit out of it with the EMU but not that big of a step for the rb20 on a standard turbo.
looks like its a good base for a turbo upgrade. if your worried about a turbo upgrade getting unwanted attention then a high flow is definantly the go. you've already got the supporting mods to make some good power.
Edited by QWK32
thanks for the suggestions guys. Lol and and dont bag the hyundai. Nothing wrong with korean made cars......lol
as some of you have guessed, the car is an rb20. i like the sound of the new afm and high-flowed turbo. im guessin a z32 afm is legal still??
if you want it to still look stock but go a fair bit harder, pick yourself up a forklift bottom end and chuck all your top end goodies on it.
that and a highflow will get you up around 230 / 250 kws, and still look like a stocker.
bottom ends can be had for around the $100 mark and then find yourself a second hand rb25 highflow from the fs section, and for $1000 you will gain 75 kws.
cheap power really.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
