Hi there,
Just fitting up my new GCG bolt on turbo and I am at the stage of cranking the engine to check there is oil coming out of the drain.
I have filled up with over 4L of oil and disconnected the CAS and have cranked for about 3 lots of 5 seconds each and there is not really much oil coming out of the drain (maybe not any!).
The manifold appears to be wet with either oil or fuel running down probably originating from the turbo.
I have a new gasket and torqued up the nuts turbo to manifold.
The only thing I can think of is that I torqued up the top oil and water lines first before these nuts. I didnt think this would interfere with getting the right torque on the turbo nuts and clamping the gasket.
So I have 2 seperate issues:
1. No oil coming out of the drain
2. Appears to be fluid running down from turbo on the underside of manifold.
Anyone else had these issues?
Thanks
https://www.sau.com.au/forums/topic/187306-fitting-new-turbo-problems/
ive had a closer look it may have been there before from product that the stud remover bloke used.
Main problem - NO oil to turbo
I have taken the oil inlet banjo off and when I crank the engine there is no oil coming out. This is with the CAS disconnected. Maybe there isn't enough pressure built to get oil to the turbo? Anyone triied this?
GCG recomend to check there is oil cooming fro the drain by cranking the engine but not staring it. However the oil inlet to turbo is quite high so some pressure would ben needed to get it up there
Edited by benl1981
  benl1981 said:
Also - does anyone see a problem with bolting up the oil and water inlet first then tightening the turbo to manifold nuts?
This will not cause a problem at all.
Give the engine a longer crank. you will not build much pressure doing 5 second bursts, and like you said the oil feed for the turbo is up fairly high. It'll take a good 30 second crank to get the factory low pressure light off.
personally, id unhook the oil return and put in into a bucket and then start the engine, give it 10 seconds and then switch it off. then go check the bucket. You didn't have oil issues before, whats changed now to make you think you have some?
thanks bhdave - So you think my gasket should still have the orect pressure on it? I was going to undo the bangos then tighten the manifold nuts p first but its a bit of a hassle since the tabs have already been knocked back etc.
Will try a longer crank
Thanks- yeah no issues before with oil supply :P
PS - anyone know which fuse does the injetors or fuel pump - so i dont have to be cranking fuel fo that time
Edited by benl1981
Don't know about injector fuse, but you can unplug the connector at the back/top of the block, which you usually unplug when changing sparkies.
Fuel Pump one is in the boot i think, near the battery? Check the Fuel Pump DIY threads, might be in one of those somewhere.
As long as you are 100% positive the banjo bolts are pointing in the right direction then how can you stuff it up? I just bolted it all back together and started it. I was super careful about the banjo bolts though. I hope you used new copper washers.
Been busy on the weekend. Got oil out the drain so all is good. Just got to bolt up exhaust and test.
Then do the injectors and tune :rolleyes:
Wanted to do one step at a time so I can identify cause of problem if any. Very slow process!! mainly all due to turbo issues.
Will test it tonight to see that the turbo runs ok and no surge..better not or ill spew!
Turbo is all on. Runs well - no surge.
No leaks or anything - the only thing is as soon as you shut off the car and put your head near the turbo you can hear sort of air or water moving. Can anybody else hear this. I didnt notice with the last turbo but I may not have paid that much attention.
From 4000-7000rpm is really strong. I'm only running about 9psi though. Slightly laggier but not much. Might be good for traction as it doen't seem to snap on boost quite as sharply as stock turbo. Running without a tune so really rich. Maybe with some tuning and more boost it will be good :laugh:
hope the clutch holds up :woot:. Yeah Ill do the injectors soon.
Also got the new fuel pump to go in (GTR). Hope it's quieter than the one in there. For some reason my car doesnt seem to have the dual stage - so at idle it isn't any quieter that when the revs go up. All the wiring looks stock though.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 馃憣). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
