Custom Coil Pack Covers - Group Buy #2 - Closed
Well that certainly f**ks me over... spose I'll put the car back together now...
sorry mate :D
just got a email saying that the Polished covers will be sent tomorrow and the powder coated ones later this week :cheers:
  • Replies 177
sorry mate :)
just got a email saying that the Polished covers will be sent tomorrow and the powder coated ones later this week :)
killa im glad i got a polished 1 cheers for keeping us informed on the stuff arounds mate
lol its just a cover, its not like you have to rip the engine out, it takes 5mins to stick a cover back on, or better yet drive around with nothing on
I'll be keen if theres another group buy, so i'll keep checking :)
Yeah there's nothing on there now... But I have to move the car somewhere, and most of the piping and shit was undone just to make it easier on myself...
sorry mate :)
lol, dammit, I could have waited that long, now i gotta rip apart the block, and replace the piston rings you fried...
I mean, change the coil cover... again :wave:
heres the latest
Posted Wednesday (Nov 14th)
Mark Hughes - CA18DET
Auto Indulgence - SR20DET Black top
Chris Howlett - SR20DET Black top
PSI Parts - RB25DET , SR20DET Red top ,SR20DET Black top , CA18DET
Posted Thursday (Nov 15th)
the remaining mirror finish covers
and also all the covers that need powdercoating have been dropped off today (thursday Nov 15th) to the powder coater-er, more than likely to be posted on monday
sorry about the delay guys :wave:
Edited by Brycey
beauty :(
im surprised that some havnt arrived already if they were posted on wednesday.. none the less there should be packages arriving at doorsteps early next week :P
beauty :ermm:
im surprised that some havnt arrived already if they were posted on wednesday.. none the less there should be packages arriving at doorsteps early next week :D
so maybe monday we shall receive these items
assuming so mate :D i thought the packages would have arrived friday, but monday should be the day for the polished covers :D
:ermm:
Edited by Brycey
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
