Hey Guys
Its just a stock '93 GTS-T typeM with a front mount, pod and some stiff springs for the performance, and a GTR front bar, grill, bonnet and rear wing for the women :cool: (My girlfriend :blush: )
Eventually I hope to go the path of street driven, track/motorkhana/am drift/tarmac rally weapon, keeping power low and mostly working on the twisties and reliabilit.yI might go for a touch up or respray if I can tear the funds away from the performance parts, but I am pretty happy with how it looks :woot:
I know I'm not the most common person on these forums, but I never really owned a turbo skyline before, so you will probably see and hear a lot more from me now. :D
Here is the link to the sale post, as my computer is stuffing up and wont allow me to post pics :P
CLICKY CLICKY
Edited by TURISMO
https://www.sau.com.au/forums/topic/187380-my-new-baby/
This Saturday should be awesome, should find out what she is like.
I like the wheels, but I also like GT-R wheels, and these ones will look good as stockies then + GTR rims, ALOT lighter
Bullet, why don't you make a Federal RS for the 32 GT-R rims, not happy jan :thumbsup:
https://www.sau.com.au/forums/topic/187380-my-new-baby/#findComment-3390907
Bullet, why don't you make a Federal RS for the 32 GT-R rims, not happy jan :happy:
She really is bewdiful (I saw her for real on Sunday).
Can't get RS's for your rims??? :huh: ouch!!!
:) my 595RS's on my GTR, she looks even sexier now :wub::wub: and doesn't squeal like a biatch around the track anymore :thumbsup:
https://www.sau.com.au/forums/topic/187380-my-new-baby/#findComment-3391275
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
