Guest carasky
hey guys i have 20 wheel nuts available open ended (good for track and drag work as most require them to be open ended) to suit 1.25 studs which all nissans have.
Black in colour and brand new only opened one packet to check only to find it doesnt fit the studs on my soarer.
They have WORK printed on every single one and are genuine not fakes.
Price: $85 plus delivery to anywhere in aus for extra $5 (this is very cheap guys)
located in melbourne.
ph:0404456860 or just pm me here.thanks
https://www.sau.com.au/forums/topic/187458-work-wheel-nuts/
work definately make black, steel, open ended nuts. I just bought some from work in japan. they look like the pic and say "work wheels" down the side of each nut.
https://www.sau.com.au/forums/topic/187458-work-wheel-nuts/#findComment-3397076
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
