Hi guys, i recently purchased a 1996 s2 r33 gts-t. Im soon to be installing a aftermarket FMIC (proberly Just Jap).
Can any guys who have installed a intercooler kit who have a stock series 2 front bar please write up or show pictures (woulb be better) of what had to be cut, moved or removed completly.
Thankyou
p.s. please no chit chat, just info and other helpful tips or pictures. :D
https://www.sau.com.au/forums/topic/187466-r33-intercooler-installation/
You will have to cut the black plastic bit out of the mouth of the front bar.Cut a hole under your washer bottle for the pipe to come through.But if i were you i would get a dump/front pipe before doing an intercooler.
search the tutorial forum section, theres a guide for the ARC kit (the one that pipes into stock positions, pipe pulls a 180 on the cold side and loops back underneath) and also one for the Hybrid (similar to Just Jap kit) so just search around. From memory though the Just Jap ones require trimming of the fan blades, cutting under washer bottle and trimming of the front reo bar.
heres a guide to where you'll need to cut the hole, under the washer bottle that i ripped from the other thread:
you'll need to cut out the front reo bar in 2 places for the fmic to fit up to 2 existing holes on it (you'll see them when you take the bar off).
ive seen plenty of s2 installs that dont need the front bar to be hacked into with the JJ kits.
its the series 1 bars that need butchering.
I noticed there are two small items i think they are the horns in front of the radiator behind the front bar, do they need to be relocated? does the bar behind the front bar need to be cut to fit the cooler or compeltly removed?
I did look at the two guides, they wernt much help. The Arc kit guide was great, but im not using that kit, so i need to now for a JJ kit. Does the washer bottle need to be re-located? dose the front intrusion bar need to be cut into or removed altogether.
If you cna find any other links for install. please put them up :D
yeah i just installed mine and haven't put the horns back on yet not sure where a good spot is yet, I got mine in without hacking the reo also I hacked my thermo fan and front bar lights instead eek!
Edited by SevenAngryPenguins
Got any pics of it all installed? wot did u do with ur washer fluid bottle?
yeah i just installed mine and haven't put the horns back on yet not sure where a good spot is yet, I got mine in without hacking the reo also I hacked my thermo fan instead eek!
I installed the JJ kit on my s2. No trimming of fan or moving horns. Have to cut the centre section of bar out, a little out of sides of bar to allow room for pipes and cut a little bit of plastic bracket off washer bottle if you have to. I also got my mate to weld on a nipple for the boost line. Quite simple, just take your time cutting the front bar as you don't want to cut too much at once. I'm happy with the kit, looks awesome! :blink:
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
