What Would You Choose
28 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey there guys, im new to the whole skyline thing and about to purchase one... problem is, what one?
Im either going to go a R32 Gtst or a R33 Series 2 Gtst
Would would people suggest?
I know i can buy a R32 cheaper and spend the money on it... or just buy a newer car with some mild mods
or pro's and cons of either one...
Any help would be most appreciated, Thanks guys
-Griffo-
Edited by Griffo04
https://www.sau.com.au/forums/topic/187676-new-guy/
im sure this topic will be pretty biased.. but here goes:
i would choose the 33 s2 simply because its newer, more powerful, bigger turbo, may have less km's, mild mods will see it with some pretty good numbers...ect ect..
realistically, you need to choose what you like, some people absolutly hate the look of 33's, while others hate 32s. regardless of that, the way i look at it, the newer more modernised updated version is ussually the winner.
of course people will argue against it, so the best influence and decision is your own.
also list some specs about both cars. i.e what year, current mods, future mods, kms, ect.. that will then make better opinions than just whats better a 32 or 33.
good luck and welcome! :bunny:
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3386591
i got a series 2 r33. IMO - it looks bloody nice (specially the back), more power, more space inside, nicer interior etc. And as mentioned - minor mods can make a huge power difference to the stock version. However, the car is big (compared to the r32) - both bulky and its as long as a family sedan.
R32, is old - so there might be more problems than the r33 - but this comes down to how the previous owner used it. If it straight from japan, you probably would never know how the previous owner used it (i.e if ur buying one off a SAU member, u will have an idea as to what the car has been through).
Both are great cars on the road and track....pretty much, either one u go for, u cant lose - unless u buy a lemon.
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3387204
both are old, heck even R34's are getting long in the tooth,
Depends how the particular car you're looking at is kept
Personally I'd go the Series II R33, with the front lip they can look quite mean
Good luck with your purchase
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3388151
Thanks for the advice guys, looks like the 33 S2 is the members choice, but still i guess it does come down to my own decision, i do love the style and look of a 32 but the 33 being newer and a better chance of having less problems is prolly going to be my choice.
All i have to do is find a decent one in brisbane that isnt over priced....
https://www.sau.com.au/forums/topic/187676-new-guy/#findComment-3388597
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
