From what people have said who I have asked with regards to the radiator cap they should be ok. Many holden/ford cooling systems run a 1.3bar system and the cheepass chinese radiators for these have no probs with the caps so I don't expect these to be any different. Obviously over time any radiator is going to deteriorate and eventually rupture for one reason or another. The best way to keep a radiator in good shape is good coolant and regular changes to keep the system clean.
Anyway, when I get mine, sometime next week now :/ cos autotechnica have no stock will let you all know how I go.
  • Replies 285
hey is anyone knowing what fatz is upto? i tried calling his fone this whole week but no ones answered....:) i already deposited money into his account etc so anyone know whats ahppening with him?
Cheers
Chi
Anyone in wa ordered a r33 rad but hasnt fitted it to their car yet? i would like to test fit ie slide into place in my cefiro to see if it clears the bonnet. cheers froggah
just been at the casino spending all ya coin people!!!!!!!!!!!!!!!!!!!!!!!!!!
lol :P
basic rundowm:
as soon as your money is deposited into my account I send it to the supplier with your address
it then arrives hopefully in a day or two at your joint(normally about a week)
worst case was 2 weeks due to a lack of stock back at Christmas time
I don’t make any coin on these so be nice :P
I seriously encourage people to pick them up from seven hills as it avoids me dealing with people who presumably are risking 3 years salary, or so it seams as they call me 8 times 3 seconds after depositing the coin.
Stay cool breath and after 7 days call me to give me shit
cores are smaller than end tanks...
Yah, the core isnt the same width of tank, moot really.
Has anyone fitted one to an R32 yet? Any issues?
Dummied it up week or two ago. Check my b l o g for a picture installed - don't laugh :ninja:
The unit sits 10mm lower then the stocker. (you can just see the top support rods don't really clear the top bracket rubber mounts, in my photo)
No real issue, as you can just flip the brackets upside down, flip the rubber mounts around too.
With fan shroud bolted up, the blades have heaps of room to spare.
Edited by GeeTR
hey all spoke to pete/fatz, he will be on holidays for the next 2 weeks but those who have ordered latley will be sent out and if you want to find out delivery time frame speak to john at UAS while pete is away.
cheers.
Hi guys,
How hard is it to replace radiator on R33? It is a matter of removing top mounts,loosening fan shroud and pull up? Are there any tricky items? Do you have to remove the fan to access? I was told 2 hours to replace which suggests that it's not a super quick thing to do?
Thanks for your help in advance. Have searched for Radiator link in DIY but they seem to have been removed.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
