The next person that posts crap in this thread or argues about the price being asked will receive a warning.
If you don't like the price a seller is asking for an item, look elsewhere.
  • 4 weeks later...
I paid 1200 for a PS3 with 3 games brand new (60 gig version with Resistance, Fight Night and Motorstorm).
$850 is a very good price. The $699 version also does not have wireless capability, something that was a must for me
since i got it mainly to play online. If you put it up on ebay it should sell within a few days. GL
My brother just bought the $699 version and i helped him set it up. Hooked it up to wireless internet some he can play online.
The new version does have wireless.
Plus, the guy above states he has a reciept for the purchase...sounds like he played it and didnt like it....
Also states its the new version released "this week" which implies its the newer "povo pack version".... So many loopholes to get you guys on.
Wrong - Wrong - Wrong - Wrong :happy::thumbsup:
All fun intended..I bet someone has to post something to put me down next...bet ya. Someone will act up for sure.
Edited by SunnyCoast
Just wondering if you have already paid for this?
Might be easier to work out a deal with someone for something they specify, or even a swap for the vouchers.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
