So the car comes off the road, some parts are tentatively sold, some are completed sold. but thats another thread.
Here is the Current Specs on the car:
1989 Nissan Skyline GTR
89,000kms
Strong RB26 at compression Check (160-160-160-160-165-170)
NISMO Adjustable Coilovers
NISMO Front and Rear Strut Bars
NISMO LMGT'3 with Advan A048's(sold)
NISMO N1 Front bumper
NISMO Twin Plate (slipping)
NISMO Downpipe
NISMO R32 N1 Turbos 14411-06U00 600HP
HKS High Power Catback (no cat)
BLITZ Air Filter Pods
IMPUL Ecu (looking to sell to get PowerFC with Commander)
APEX'I AVC-R Boost controller (currently @ 1.0Bar)
BLITZ VGTT (Voice guided Turbo Timer)
JDM Grounding Kit
Escort Passport SR7 plus Shifters ( $2000 Radar Jammer )
Pioneer AVHP6800 6 disc dvd player with:
-Bluetooth
-Vehicle Dynamics
Compustar 2-way Alarm
Innovative Motorsports LMA-2 with RPM kit
Blazt consult interface
White Face Gauges
List of parts ready for the conversion: over 11K in OEM parts from Japan
R34 GTR OEM Aluminum Hood
R34 GTR OEM non-xenon Headlights
R34 GTR OEM Front Bumper with lip
R34 GTR OEM Front Air Diffuser
R34 GTR OEM Front Grille emblem
R34 GTR OEM Front Marker Lights
R34 GTR OEM Z-tune Sideskirts
R34 GTR OEM Z-tune Rear bumper Skirt
R34 GTR OEM Rear Bumper
R34 GTR OEM Rear Tailllights
R34 GTR OEM Trunk
R34 GTR OEM Trunk brake light
R34 GTR OEM Factory Metal Quarter Panels
R34 GTR OEM Metal behind taillights Panel
R34 GTR OEM Back up Lights
R34 GTR OEM Trunk Weather Seals
R34 GTR OEM Red Valve Covers
R34 GTR OEM Nur Engine Ornament
R34 GTR Fiberglass Spoiler
R32-R34 Fiberglass Conversion Fenders
Replica LMGT4's with 265/35/18 Advan Neovas
Pictures Will be updated as removed or installed.
thanks for looking,
One year of buying parts has almost finally paid off.
https://www.sau.com.au/forums/topic/187948-mwr34-r32-r34-full-conversion-build/
  • Replies 241
Posted Images
Thanks that was quick!
And to all who view this..
I am looking for a R34 GTT/GTR Dash center console/arm rest
And possibly sell my non-xenon for xenon lights.
and a used R34 GTR MFD. Stock or Nismo 1 version.
Edited by mwracing
At first I thought you were just doin a r34 face ala Bee*R conversion.
But I read a little deeper and damn im impressed - full conversion? your nuts but love to see the results.
Will keep my eye on this thread :P
thanks everyone.
i just got a PowerFC to throw in there.. and a NISMO FPR.
looking for 550-700 CC injectors...
I love the rims too.. especially the 265/35/18 Advan Neovas on there.
The whole plan is to try to replicate the R34 Nismo Z-tune.
So the Car will be painted KY0 silver, and the rims were to help the effect of the z-tune look.
And yes, this is definitely NOT a cheap Bee-r Kit. 100% custom made with 95% OEM parts.
oh i dont know if anyone noticed but i have custom license plates "R34 GTR" registered on this car.
Top choice on the colour mate.. i was thinking in my head that'd look best on your ride, that and the millenium jade. And yes i did notice the R34 GTR plates, weren't sure if they were just made or registered... top work !
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
