Hey All,
I need cash, so the missus has convinced me to sell the baby. It's only fair i guess seeming as how it sapped all the money in the first place. Goes like this.
1996 R33 Series 2 Gts-t
-5 speed manual
-112 xxx kms
-Resprayed by Candyman Spray Painting in Sydney in Jet Black
-Car gets regularly washed, polished and waxed using only top quality products
Brand New Engine Rebuild.
Consists of the following
CP Forged Pistons, Eagle Rods, Tomei Metal Head Gasket, All New Nissan Gaskets, Extensive Head Work, Head stud kit, N1 Oil Pump and Collar to suit, N1 Water Pump & Nismo Thermostat, HKS Step 1 Cams, HKS Cam Wheel, Z32 AFM, HKS GTRS Turbo, 555cc Injectors, Bosch Fuel Pump, Split Fire Coils. There is alot more that has gone into it, but this should give you an idea on the kind of quality parts that have been used. For exact specs on head work or any thing else please call me and i can put you in touch with the man who built it. Car has only travelled 1500k's since the build and hasnt even had a run down the strip yet. The above work/ parts cost me 20K,( with receipts) and has an engineers cert to boot.
271 RWKW @ 18Psi (very safe tune)
Others Mods etc:
•Genuine Gtr bodykit (obviously isnt a perfect fit with the gtst gaurds)
•Carbon Fibre reverse scoop bonnet sprayed with a clear coat (with bonnet pins)
•17 inch Volk EMU Racing rims resprayed in Black fitted with near new Hankook K104 255x40 (rear) Yokohama 235x45 (front)
•Tein height adjustable coilover suspension, hard but not uncomfortable
-Cusco Front Strut Brace
•DBA4000 slotted rotors front and rear
•DS2500 front brake pads, RACEBRAKES rear brake pads
•Cusco castor rods set to 8 degrees castor
•GFB Stealth Fx blow off valve (fully adjustable, can be fully closed)
•3inch split dump/front pipe into 3inch CATCO hi flow cat continues into 4inch through to 7inch cannon with 5inch fluted tip, also have a legal bolt on end muffler.
•Power FC & Hand Controller
•Apexi AVCR Boost Controller
•Apexi Turbo Timer
•Apexi boost gauge
•Apexi pod filter
•Twin thermo fan set-up with 1x12inch & 1x14inch fans
*New Battery
•Genuine C’s shortshift kit
•Aftermarket steering wheel, pedals and Gear Knob
*Nismo Clear Indicators
*Aluminium wheel nuts
•Stock diff re-shimmined
•Hybrid Tube & Fin 700x300x75 FMIC fitted
•Excedy 5 Puk Ceramic clutch with RPM brass button pressure plate
*New stereo inc, Alpine MP3/ Ipod Control Head Unit, Alpine V12 amp running 6 inch Kenwood splits in the front and a Soundstream SPL 12" sub.
There is more as well, but i think you get the idea by now, this car has everything you could ask for and will cost you
ALOT less to buy than what it cost me to buy and build.
Custom Plates SLO33R included in sale
$24,990 or near offer
call me on 0409 910 960 for any other questions you have.
attachment=122597:05_10_07_017_10_1.jpg]post-3771-1191555835_thumb.jpgpost-3771-1191555903_thumb.jpg
https://www.sau.com.au/forums/topic/188053-96-r33-gts-t/
  • 4 weeks later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
