  • Replies 136
Posted Images
Damn. I think I just saw you guys about half an hour ago on Springbank road going the other way. Was on the way to pick up my missus and didnt know about it till now. DOH!!! I always go out on Friday nites driving and this is the one I chose to stay home. I really should read the forums more often. Hope you guys have fun
Was a good cruise, except for some f**king punk in a twin cam corrolla tail-gating me before giving a love tap, on the way to Windy point. counting my lucky stars there was no damage :wub:
some really nice cars you guys have :cool:
+1 the cruse was great, it was my 1st skyline cruise. Cheers for organising it SLY - dN... apart from the fact that the cops followed me for ages on my way home :wub: from the corner of grange and taps, all the way to corner of oaklands and brighton. they were tailgating me, then pulling up next to me, then they would drop back. and fkn come screaming up behind me again. (worse than taki drivers LOL) In the end they took off, spose cos i did not react, just stayed in my lane doin 60. ANYWAY the cruise was great fun, all cars were well turned out :cool:
good cruise, thanks SLY-dN now you know how easy it is to organise next one wont be so daunting
if anyone ever needs help to get maps or stuff just holla
only got 2 great pics rest are bit grainy or too dark
